1962 corvette - NCRS Discussion Boards
1962 corvette
  • Harry G.
    • September 23, 2010
    • 13
    1962 corvette
    Do I have to open the rear end and remove C clip or pin to pull out the rear axles?
  • Mike M.
    • May 31, 1974
    • 8408
    Re: 1962 corvette
    no, just pull axles. mike
    • Bruce B.
      • May 31, 1996
      • 2930
      Re: 1962 corvette
      Mikes correct.
      But if your car has a rear end that you can open from the rear it is not original to a 1962 Corvette and it might have clips on the axles.
      The 62 rear end pumpkin (center section, etc) can not be opened with the axles in. The 4 bolts holding the axle retainer (on each side) need to be removed to pull the axles.
      • Robert K.
        • July 31, 1984
        • 213
        Re: 1962 corvette
        And a big slide hammer!!!!!!!!!!!
        • Terry D.
          • May 31, 1987
          • 2697
          Re: 1962 corvette
          You can borrow the slide hammer from Auto Zone
          • Bruce B.
            • May 31, 1996
            • 2930
            Re: 1962 corvette
            Make sure you borrow one with the 3 bolt axle puller attachment.
