C-3 coupe body lift - NCRS Discussion Boards
C-3 coupe body lift
  • Justin S.
    • July 3, 2013
    • 305
    C-3 coupe body lift
    Has anyone ever lifted a C-3 coupe body off of the frame using the straps that hook under the door sills and come to a center point? I think Corvette Central sells them.
  • Bill W.
    • March 1, 1980
    • 2000
    Re: C-3 coupe body lift
    Yes I used them to remove my 70 coupe body . The ones I had put allot of strain on the body panels . I think there are better ways to do it . I have also used a cherry picker with a cross bar and chains going to the door striker and the hood latches . My favorite is a set of camper jacks . One person can remove or install a body .
    • Justin S.
      • July 3, 2013
      • 305
      Thanks Bill. By body panels, did you mean the T-top panels? I wasn't sure if I should take those off for the lift or not.
      • Bill W.
        • March 1, 1980
        • 2000
        Justin the ones I used clipped under the rockers and were very tight against the front fender and door . I would not use it again . The safest way would be a two post lift with swing out arms . I used these at work before I retired . At home I use camper jacks .
