HEI ignition system from 70's chevy to 57 283 - NCRS Discussion Boards
  • Theodore K.
    • December 1, 1985
    • 214
    Does anyone have any experience in adapting a HEI ignition system from the mid 1970's Chevy's to use in a C1 car? What problems were encountered? Was any improvement noticed? I have the dual point system that I had rebuilt when I rebuilt the engine. Thanks, Ted
  • Mike M.
    • May 31, 1974
    • 8400
    Re: HEI ignition system from 70's chevy to 57 283
    measure the distance from the back side of the original style distributor cap to the firewall. measure the radius of the hei dist cap. there may well be interference. mike
    • Jim T.
      • March 1, 1993
      • 5351
      Change out the distributor gear from your 283's distributor to the HEI. Adjust end play if needed. One wire hookup to full time 12 volts. Using HEI in my 1970 since I installed a ZZ1 GM crate engine in early 90's with no problems.
