C6 healight condensation - NCRS Discussion Boards
  • Andrew K.
    • February 17, 2012
    • 11
    How do I remove the plastic headlight cover on my 2009? The inside has a layer of condensation on it.
  • Rick A.
    • July 31, 2002
    • 2147
    Re: C6 healight condensation
    Common occurrence on C6's - will eventually dry out. Let it set out in the hot sun, or conversely if you are adventurous, there are rubber boots inside the fender well (should check and make sure they are in place!) that you can point a hair dryer through to dry out - takes some time.
    Rick Aleshire
    2016 Ebony C7R Z06 "ROSA"
    • Bill W.
      • March 1, 1980
      • 2000
      Gm says if it drys out by noon outside on sunny day it should be considered normal .
      • Andrew K.
        • February 17, 2012
        • 11
        Thanks, I will look for the boots and give the hairdryer a try.
          • 15616
          Just in case you really, really want to open them up:
          http://forums.corvetteforum.com/c6-c...ht-lenses.html
          There are other threads ont he same subject there, but I think you have to register (it's free) to search.
          Personally I wouldn't do it. Have you looked at the price of a replacement from GM? I bought a spare set for just-in-case, and I can tell you what they were four years ago. Take a deep breath and be seated.
          • Andrew K.
            • February 17, 2012
            • 11
            I opened the boot in the wheel well to let some air circulate and parked in direct sunlight for 3 hours. To my surprise, most of the condensation is gone. It was really heavy condensation . Much easier solution than I expected. Thanks for the great and quick responses.
              • 15616
              I am glad to hear that worked for you.
