How do I remove the plastic headlight cover on my 2009? The inside has a layer of condensation on it.
C6 healight condensation
Re: C6 healight condensation
Common occurrence on C6's - will eventually dry out. Let it set out in the hot sun, or conversely if you are adventurous, there are rubber boots inside the fender well (should check and make sure they are in place!) that you can point a hair dryer through to dry out - takes some time.- Top
Just in case you really, really want to open them up:
http://forums.corvetteforum.com/c6-c...ht-lenses.html
There are other threads ont he same subject there, but I think you have to register (it's free) to search.
Personally I wouldn't do it. Have you looked at the price of a replacement from GM? I bought a spare set for just-in-case, and I can tell you what they were four years ago. Take a deep breath and be seated.Terry- Top
I opened the boot in the wheel well to let some air circulate and parked in direct sunlight for 3 hours. To my surprise, most of the condensation is gone. It was really heavy condensation . Much easier solution than I expected. Thanks for the great and quick responses.Just in case you really, really want to open them up:
Personally I wouldn't do it. Have you looked at the price of a replacement from GM? I bought a spare set for just-in-case, and I can tell you what they were four years ago. Take a deep breath and be seated.- Top
