1968 Splash guards - NCRS Discussion Boards
1968 Splash guards
  • Jeff P.
    • 799
    1968 Splash guards
    My March coupe didn't have these. The June convertible does. I also notice that the mounting tabs are riveted on. Replacement pieces have the tabs as part of the guard. Was the riveted tabs a " 68 only part" ? Thanks in advance.
    68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
    2014 Arctic White Z51 Vert. (Wifes)
  • Dale C.
    • November 1, 1999
    • 844
    Re: 1968 Splash guards
    The new Judging Guide has good info (plus the Service Letters) on the under body shields. The numbering or order of the pages is messed up. I copied them and put them in the correct order and its easier to understand. Dale
    • Jeff P.
      • 799
      Thanks, Dale. I didn't see the bulletins.
      • Jim T.
        • March 1, 1993
        • 5351
        Jeff my original owner 1968 has its original splash guards and it was built in Feb 1968. A piece of metal is riveted to the fiberglass and the splash guard bolts to this tab and to the frame.
        • Jeff P.
          • 799
          I might have the term wrong. Shields or guards. Anyway my 68 march coupe doesn't have them. My 68 June convertible image.jpgdoes. The passenger side isn't there. Lost or fell off in the past. Ill have to hunt this part down. Here are pics as to what I'm talking about.
            • 15643
            Originally posted by Jeff Pollard (15573)
            I might have the term wrong. Shields or guards. Anyway my 68 march coupe doesn't have them. My 68 June convertible [ATTACH=CONFIG]47170[/ATTACH]does. The passenger side isn't there. Lost or fell off in the past. Ill have to hunt this part down. Here are pics as to what I'm talking about.
            Jeff,
            Looks like you are talking about the guards (shields) that are parallel to the ground. There is another set on the toe board (opposite side of where the feet rest).
            If these are the ones parallel to the ground there is an extensive TSB (Technical Service Bulletin) about them reprinted in the 1968-68 TIM&JG. I believe that TSB has some serial numbers or build dates in it that may help you. There are part numbers in it, but those will now be useless.
            • Cecil L.
              • May 31, 1980
              • 450
              Is this the TSB you are referencing?
                • 15643
                Yes that si one. There is, I believe, another perhaps in 1969 that describes the addition of fiberglass with aluminum covering as a heat insulator between these shields and the body and the same material added to the storage compartments behind the rear seats.
                Cecil, Nice size on those pages. Is that because of a third party hosting site?
                • Cecil L.
                  • May 31, 1980
                  • 450
                  Yep, I use Photobucket for that sort of document. Just about anything else is just not legible.
                  BTW, I may have that TSB you reference but are you sure it's not 68-T-43 that this TSB supplements?
                  • Cecil L.
                    • May 31, 1980
                    • 450
                    Here's the original 68-T-43 TSB that the one above supplements. Is this the one you were thinking of?
                      • 15643
                      That is one, but not the one I was thinking of. If it wasn't so late, and I didn't have things to do that are more important to me -- I would look for it. They are all in the TIM&JG as I noted in another thread you started.
                      Doesn't Photobucket have limits on the number of views an image can have. I see a lot of threads with the image gone after some time -- which makes the posting next to useless in many/most cases.
