Corvette Clutch Throwout bearing - NCRS Discussion Boards
  • Bob H.
    • July 31, 2000
    • 807
    Hi
    It's been awhile since I replaced a clutch on a C2. My thowout bearing was going bad so I replaced the clutch as well. My question is I purchased the clutch from NAPA and noticed the throwout bearing was grooved on the inside. I hadn't seen that before as ones I have changed were always with a smooth surface. Is this something new and what is the purpose? It is a big block if it matters.
  • Joel A.
    • September 30, 1997
    • 214
    Re: Corvette Clutch Throwout bearing
    You mean there is an open space inside the sleeve that rides on the trans collar? If so, then that is "normal"....it is a reservoir/space to put grease for lubrication.
    Joel Adams
    1974 Coupe
    1985 Coupe
    "I know the voices aren't real...but sometimes they have some really kewl ideas...."
    • Bob H.
      • July 31, 2000
      • 807
      Hi Joel:
      Yes. I one I removed had a smooth surface inside. Although I greased the collar I did not fill it with grease. Will that be a problem in the future?
      • Michael M.
        • February 7, 2011
        • 186
        I recently bought what sounds like the same LuK clutch kit through Napa. Mine came with a composite throw-out bearing made by INA. I found that INA and LuK are part of the Schaeffler Group North America and probably why they were packaged together.
        Some may like the composite bearing but I’m kind of old-school and decided to go with a conventional SKF bearing made in the USA (also from Napa). The composite bearing may perform just fine but I didn’t want to take a chance and go through all the labor involved to change it down the road.
        The choice is yours and I'm sure some will say the composite bearing is superior.
        The first pic is the SKF I went with, the second is the composite bearing that came in the kit.
        • Bob H.
          • July 31, 2000
          • 807
          Mike
          That is the bearing I was talking about. Thought I was making the right decision buying the NAPA/LUK clutch but now......
          • Michael M.
            • February 7, 2011
            • 186
            • Bob H.
              • July 31, 2000
              • 807
              As with most of our cars, I don't put that many miles on it. My problem happened as I was pulling into Kissimmee in January. Took me this long to finally replace it. I would hope it will last a few thousand miles which will take me awhile to achieve.
                • 43219
                Bob-----
                I strongly suspect that the INA bearing is going to last longer than you're ever going to need it even if you started driving the car day-to-day. Clutch release bearings have been somewhat problematic for years. During the last 15 years, or so, design changes have occurred in an attempt to solve some of these problems. I feel pretty confident that the INA design is among those.
                • Bob H.
                  • July 31, 2000
                  • 807
                  Thanks Joe. I needed some reassuring words
                  • Bob H.
                    • July 31, 2000
                    • 807
                    Would it be prudent to remove the transmission and fill the grooves of this new style throwout bearing with grease. I just put a light coat on the tranny collar
                      • 6942
                      Bob, Maybe if you need to you could access the trans sleeve through the boot around the fork if need be later. You really only need a small amount of grease anyway. You don't want to be slinging any grease around in the bell housing or get any on the disc. smooth operation in and out with pedal is the main concern.
                      • Bob H.
                        • July 31, 2000
                        • 807
                        Thanks for that thought. I will check that out. My thought too, was I don't want a bunch of grease slinging around. Would like to get a small amount in there though.
                        Guess my old school thinking and way of doing things needs updated!
                        • Jim D.
                          • 2884
                          Bob, I wouldn't worry about it. I've been using the Luk clutch set in several cars for many years. They all have the same T/O bearing. I put a thin coat of grease on the bearing retainer and that's it. No problems so far. I'm one of the ones that think the composite bearing is far superior to the metal ones.
                          • Bob H.
                            • July 31, 2000
                            • 807
                            thanks Jim
                            • Gerald C.
                              • June 30, 1987
                              • 1281
                              I'm installing a new throwout bearing in my 63 300HP. I purchased SKF N1488 from NAPA. I'm installing it (off of the car) and it slips out of the yoke. I am installing it correctly with the tabs inside the rear of the bearing. However, it seems to fallout easily! Is this "normal" and will it be okay once the bell housing is installed??
                              Seems odd that it would be this loose.
