68 doors on a 69 car. - NCRS Discussion Boards
  • Calvin C.
    • May 31, 2002
    • 240
    Still shopping, today I am checking out what is said to be a original 427 t top. The owner has indicated the car is a 69 with a 69 vin, however it has 68 door lock and 68 back up light. Is this possible. I do not know the vin yet, although it would have to be early.thanks cal
  • Philip A.
    • February 26, 2008
    • 329
    Re: 68 doors on a 69 car.
    I am not a C3 expert but to me these would be red flags. Make sure it is no a '68 that was retagged as a '69, or a wrecked '69 pieced back together with a '68
    • Calvin C.
      • May 31, 2002
      • 240
      I will take my 68 - 69 tech manual and see if I can figure it out. He is third owner and claims it is solid, no original motor of course. Also can I tell if a car was originally a 4 speed? Cal
      • Dick W.
        • 10483
        VIN would have to be way earlier than anything we have ever seen on the field. I would check the VIN on the frame, I am suspicious
        Dick Whittington
        • Terry B.
          • August 31, 1999
          • 607
          I think Philip has it right. I has been pieced back together.
          Terry Buchanan
          Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
          Corvettes Owned:
          1977 Coupe
          1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
          2003 Electron Blue Coupe
          2019 Torch Red Grand Sport Coupe
          • Michael D.
            • June 30, 1996
            • 536
            Originally posted by Calvin Camara (38021)
            ...The owner has indicated the car is a 69 with a 69 vin, however it has 68 door lock and 68 back up light. Is this possible...
            Not likely.
            Look this car over very carefully when you see it.
            • Reba W.
              • 937
              I see red flags everywhere. Bet there are more if you look.
              • Calvin C.
                • May 31, 2002
                • 240
                Well the car wasn't bad, it was an original 69 390 427 car, except from in from of the doors back was a 68 frame and body, and it came with a nice welding job on the frame, Thanks for helping call this Frankenstein. Cal
                • Bob H.
                  • July 31, 2000
                  • 809
                  So you can have a 68 and 69 for the price of one!!
                  • Jim T.
                    • March 1, 1993
                    • 5351
                    Calvin automatic cars came with bolted in/removable cross member for the transmission, manual transmission cross members were welded and not removable.
                    • Dan A.
                      • February 1, 2004
                      • 212
                      Sounds like a 68.5.
                      • Paul J.
                        • September 9, 2008
                        • 2091
                        Cal, I see these from time to time. I once went to look at a wrecked 71 and big block 72 in a package deal. The 71 was a pretzle. The "big block" 72 had no motor and 73 front end on it. Looked like the guy had four halves instead of two cars. I walked away.
                        Paul
