C2 dash pad replacement instruction - NCRS Discussion Boards
  • Jim C.
    • May 31, 2000
    • 96
    Anyone know a place to source instructions or is it self explanatory once started?
    Jim Cear
  • Paul J.
    • September 9, 2008
    • 2091
    Re: C2 dash pad replacement instruction
    Jim, its pretty self explanatory. Once you master the clips it's straightforward.
    Paul
      Jim -
      This may be helpful - it's a lot easier with the main panel out of the car.
      http://www.lbfun.com/warehouse/tech_...ip-Install.pdf
      • Stephen B.
        • April 1, 1988
        • 887
        I took the dash pads off of my '65 yesterday. The best method I found was to take a small set of vise grips to stop the clip from spinning. Then I spread the clip with the smallest flat screwdriver I had and continued to spread the clip wider with larger screwdrivers until it came out. It is pretty easy with practice.
        • Stephen B.
          • April 1, 1988
          • 887
          And I did not break a single clip with my method.
          • Bob R.
            • June 30, 2002
            • 1596
            I didn't break them taking them out but when I went to reuse them several of them just broke in half. I would have some spares around just in case.
            • Michael G.
              • January 1, 1997
              • 1251
              Jim -
              I've installed pads with main panel out of car.....no problem. I'm soon to attempt install of new pads with main panel still in car. Radio is out, will remove glove box and for ease am removing the instrument cluster.....any out pointers out there? I know some of us have did this type install.
