2013 corvette - NCRS Discussion Boards
2013 corvette
  • Jerome P.
    • October 22, 2006
    • 607
    2013 corvette
    The VIN is 1G1YS2DW4D5103043 on a 2013. Can any body tell when this car was built? I have been told that there are different production sequence numbering for the ZR1, the Z06, and still another for all other models. This VIN # belongs to a 2013 Grand Sport coupe. Again I am looking for the approximate build date. Thanks.
  • Larry H.
    • May 31, 1994
    • 63
    Re: 2013 corvette
    Jerome,
    The build date is 08/14/2012.
    Larry
    • Jerome P.
      • October 22, 2006
      • 607
      Re: 2013 corvette
      Thanks Larry. Is there a table you used that you could refer me to? Also, is it correct that there are different numbering sequences for the various model cars?
      thanks again.
        • 15599
        Re: 2013 corvette
        thanks again.
        I believe there is a different VIN number sequence for all those you mentioned in your OP plus the Grand Sport.
        Any GM parts department can find the build date, and a lot of other information, using a GM system called VIS: Vehicle Information System. That only works for GM vehicles built in the last ten years. Many parts departments will do this look-up for free; some will not do it at all for walk-ins. I have no idea if that is the system Larry used.
        The Library & Archives at the NCM can also do that for any Bowling Green built Corvette, but I don't know if they do just "information searches." They will provide you for a fee with a window sticker and a build sheet, but AFAIK neither of those have a build date on them. In the course of producing those paper documents they can find the build date.
        • Thomas H.
          • August 31, 2005
          • 1058
          Re: 2013 corvette
          Isn't the build date shown on the options label in the glove box? Or on the door jamb?
          I'll have to look at mine when I get home........
          Tom
          2007 Z06, Lemans Blue
          • Jerome P.
            • October 22, 2006
            • 607
            Re: 2013 corvette
            They are but the car is on the dealers show room floor and all I had to work with last night was the VIN. Thanks for your input.
              • 15599
              Re: 2013 corvette
              Tom
              What is on the label is the month and year of build. Some of us would like a little more fine detail. Although nothing, short of actually being there will get you the exact time of day. My 2008 was off the line 10-11-07 at 7:45 AM.
              • Thomas H.
                • August 31, 2005
                • 1058
                Re: 2013 corvette
                Yup, saw that when I looked last night.
                Now I want to know the approx day of build for mine also..................
                Tom
                • John D.
                  • June 30, 1991
                  • 875
                  Re: 2013 corvette
                  Vehicle Information
                  VIN: 1G1YS2DW4D5103043 Model: 1YG07-2013 CORVETTE GRAND SPORT COUPE
                  Service Contract: No Branded Title: No Warranty Block: No PDI Status: Yes
                  Order Type: 70 - RETAIL - STOCK
                  Field Actions: 0 Open
                  Vehicle Build
                  Model: 1YG07-2013 CORVETTE GRAND SPORT COUPE Order Number: QJVJ62
                  Gross Vehicle Weight: 1,736 Build Date: 08/14/2012
                  Build Plant: 5
                  Option Codes
                  *IVH is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
                  193 - EBONY 19I - BLACK INTERIOR TRIM
                  1SZ - PREFERRED EQUIPMENT SAVINGS 3LT - * 3LT PREFERRED EQUIPMENT GRP: * MEMORY PACKAGE * SPORT SEATS, POWER BOLSTER & POWER LUMBAR * LUGGAGE SHADE AND CARGO NET * HEATED FRONT SEATS * STEERING COLUMN, TILT AND TELESCOPIC * ADDITIONAL 9 MONTHS XM RADIO * NAVIGATION SYSTEM W/AM/FM CD PLAYER * BOSE PREMIUM AUDIO 9 SPEAKERS * UNIVERSAL HOME REMOTE * BLUETOOTH FOR PHONE * HEAD-UP DISPLAY AM/FM CD PLAYER * AUDIO SYSTEM, 7 SPEAKERS * UNIVERSAL HOME REMOTE * BLUETOOTH FOR PHONE * HEAD-UP DISPLAY * FRONT TIRE - P275/35ZR18
                  5A7 - WHEEL SPARE 6X1 - COMPONENT FRT LH
                  70U - TORCH RED 7X1 - COMPONENT FRT LH
                  8X2 - COMPONENT RR LH NON-COMPUTER SEL SUSP 9L3 - SPARE TIRE
                  9X2 - COMPONENT RR RH AAB - MEMORY PACKAGE
                  AG2 - 6 WAY POWER PASSENGER SEAT AJ7 - AIR BAGS, FRONTAL & SIDE IMPACT, DRIVER & PASSENGER
                  AJK - CONTROL SEAT, POWER BOLSTER, POWER LUMBAR AL0 - SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR
                  AQ9 - ADJUSTABLE SPORT BUCKET SEATS W/ PERFORATED LEATHER INSERTS AXJ - VEHICLE TYPE PASSENGER CAR
                  BGR - BOWLING GREEN PLANT BS1 - INSULATION ACOUSTICAL PKG
                  CF7 - REMOVABLE ROOF PANEL CJ2 - DUAL ZONE, ELECTRONIC A/C
                  D42 - LUGGAGE SHADE & CARGO NET DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR
                  DD8 - OSRV EF7 - COUNTRY UNITED STATES OF AMERICA (USA)
                  ERI - BATTERY PROTECTION PACKAGE FE3 - SPORT SUSPENSION
                  FHO - VEHICLE FUEL GASOLINE E10 GU6 - REAR AXLE 3.42 RATIO
                  I13 - ENGINEERING MODEL YEAR IL3 - TRIM INTERIOR DESIGN-AQ9
                  J56 - BRAKE SYSTEM POWER J6F - CALIPERS - RED
                  JJA - PT DRESS SUBASSEMBLY JL5 - CONTROL MANUAL TRANS, 1ST TO 4TH GEAR SKIP SHIFT
                  K63 - 110 AMP GENERATOR KA1 - HEATED SEATS
                  KNP - TRANSMISSION OIL COOLING SYSTEM KNR - COOLING SYSTEM AXLE
                  KPS - COOLER OIL, ENGINE LS3 - 6.2 LITER 436 HP ENGINE
                  MZ6 - 6 SPD MANUAL TRANSMISSION N37 - PWR TELESCOPING STEERING WHEEL
                  NC7 - FEDERAL EMISSIONS OVERRIDE NK4 - TILT LEATHER WRAP STNG WHEEL
                  NPP - EXHAUST, DUAL-MODE PERFORMANCE NU5 - EMISSION SYSTEM CALIFORNIA BIN 4
                  PYE - CHROME ALUMINUM WHEELS R9N - PROCESSING CODE - SEAT
                  SLM - STOCK ORDERS U2K - XM RADIO - SERVICE SUBSCRIPTION SOLD SEPARATELY BY SIRIUS/XM AFTER 3 MONTHS
                  U3U - NAVIGATION SYSTEM W/ AM/FM CD PLAYER, USB & AUXILIARY INPUT JACK (REPLACES STD/OPT RADIO) U52 - ELECTRONIC INSTRUMENTATION
                  U65 - SPEAKER SYSTEM 7, PREMIUM UE1 - 6 MTHS ONSTAR DIRECTIONS & CONNECTIONS WITH AUTOMATIC AIRBAG DEPLOYMENT RESPONSE AND TURN-BY-TURN NAVIGATION (ASK DEALER ABOUT GEOGRAPHIC COVERAGE)
                  UG1 - UNIVERSAL HOME REMOTE UJM - TIRE PRESSURE MONITOR SYSTEM
                  UK3 - STEERING WHEEL CONTROLS UPF - BLUETOOTH FOR PHONE
                  US3 - ANTENNA DIVERSITY UV6 - HEAD-UP DISPLAY
                  V8D - VEHICLE STATEMENT - US VA5 - ENGLISH LANGUAGE LABEL
                  VDD - VEHICLE INFORMATION DVD VH9 - ENVELOPE OWNER INFO MANUAL
                  VT7 - OWNERS MANUAL ENGLISH VZD - MODEL YEAR IDENTIFIER
                  WG4 - MODEL CONVERSION CODE XFA - FRONT TIRE - P275/35ZR18
                  XL7 - FREQUENCIES RATING 315MHZ YF5 - 50-STATE EMISSIONS
                  Z16 - Z16 PERFORMANCE PACKAGE Z51 - PERFORMANCE SPORT HANDLING
                  Z52 -
                  Added Option Codes
                  Here's when the major components were built/scanned at the assembly plant:
                  Vehicle Information
                  Vehicle Component
                  Component Code: 10-ENGINE ASSEMBLY Traceability: 31942201
                  Source Plant: 3- Part / Number Broadcast:
                  Date Scanned: 08/13/2012 Time Scanned: 07:08:00 Scan Station:
                  Component Code: 35-STEERING COLUMN - SIR SYSTEM Traceability: AA0272012
                  Source Plant: S-SAGINAW DIVISION SAGINAW,MI Part / Number Broadcast: H9L
                  Date Scanned: 08/09/2012 Time Scanned: 14:48:00 Scan Station: 07
                  Component Code: 61-TRANSMISSION Traceability: 001099
                  Source Plant: T-TREMEC MEXICO Part / Number Broadcast:
                  Date Scanned: 08/13/2012 Time Scanned: 09:41:00 Scan Station:
                  Component Code: 74-ELECTRON BRAKE & TRACTION CTRL MOD ASM Traceability: 4S2114VE
                  Source Plant: B- Part / Number Broadcast: 8428
                  Date Scanned: 08/14/2012 Time Scanned: 10:14:00 Scan Station: 08
                  Component Code: 86-ELECTRONIC CONTROL MODULE (ECM) Traceability: 22219WLP7
                  Source Plant: K-DELCO ELECTRONICS KOKOMO,IN Part / Number Broadcast: ABHD
                  Date Scanned: 08/14/2012 Time Scanned: 10:14:00 Scan Station: 03
                  Component Code: 87-BODY CONTROL MODULE Traceability: A22150147
                  Source Plant: R- Part / Number Broadcast: 4684
                  Date Scanned: 08/14/2012 Time Scanned: 10:14:00 Scan Station: 09
                  Component Code: AB-IR-MODULE ASM-INFLATOR Traceability: 2J1730125
                  Source Plant: M-MORTON-THIOKOL Part / Number Broadcast: 6063
                  Date Scanned: 08/11/2012 Time Scanned: 14:00:00 Scan Station: 04
                  Component Code: AL-IR-MODULE ASM-I/P Traceability: 8213J0045
                  Source Plant: M-MORTON-THIOKOL Part / Number Broadcast: 2416
                  Date Scanned: 08/09/2012 Time Scanned: 14:47:00 Scan Station: 05
                  Component Code: AS-SENSING DIAGNOSTIC MODULE Traceability: 122140PWQ
                  Source Plant: K-DELCO ELECTRONICS KOKOMO,IN Part / Number Broadcast: 3177
                  Date Scanned: 08/14/2012 Time Scanned: 10:14:00 Scan Station: 06
                  Component Code: AT-RIGHT SIDE IMPACT SENSING MODULE Traceability: 2102J1TNC
                  Source Plant: X- DELCO ELECTRONICS SINGAPORE Part / Number Broadcast: 2535
                  Date Scanned: 08/14/2012 Time Scanned: 10:14:00 Scan Station: 01
                  Component Code: AU-LEFT SIDE IMPACT SENSING MODULE Traceability: 2102J1TT3
                  Date Scanned: 08/14/2012 Time Scanned: 10:14:00 Scan Station: 02
                  Component Code: CD-SEQ NUM (FLEX) BODY ASM Traceability: 0500059
                  Source Plant: - Part / Number Broadcast: 1ZZ
                  Date Scanned: 08/03/2012 Time Scanned: 00:31:00 Scan Station:
                  Component Code: CF-SEQ NUM (FLEX) PAINT PROCESS Traceability: 0471321
                  Source Plant: - Part / Number Broadcast: 1YY
                  Date Scanned: 08/03/2012 Time Scanned: 04:59:00 Scan Station:
                  Component Code: CP-SEQ NUM (FLEX) GEN ASM Traceability: 0471424
                  Source Plant: - Part / Number Broadcast: 1MM
                  Date Scanned: 08/14/2012 Time Scanned: 10:25:00 Scan Station:
                  • Jerome P.
                    • October 22, 2006
                    • 607
                    Re: 2013 corvette
                    WOW!!!! This is great. Where did you fine all this info?
                    • Vinnie P.
                      Editor NCRS Restorer Magazine
                      • May 31, 1990
                      • 1567
                      Re: 2013 corvette
                      don't ask, don't tell
                      • Jerome P.
                        • October 22, 2006
                        • 607
                        Re: 2013 corvette
                        Confused. You say what?
                          • 15599
                          Re: 2013 corvette
                          I am not sure if I am interpreting correctly, but it does say "branded title no." if that means what I think it means you best ask some very pointed questions before any money changes hands.
                          That is the kind of information you can get from the VIS as I cited earlier.
                          • Vinnie P.
                            • May 31, 1990
                            • 1567
                            Re: 2013 corvette
                            Terry...I don't think Branded Title NO means what you think it means...
                            here's the same info from my 2012 Z06 which as you know was a sold order...(I have my VIS info from Day 1)
                            Vehicle Information
                            VIN: 1G1YL2DE4C510XXXX Model: 1YY87-2012 CORVETTE Z06/ZR1
                            Service Contract: No Branded Title: No: Warranty Block: No :PDI Status: Yes
                            Order Type: 60 - RETAIL - SOLD
                            Field Actions: 1 Open REQUEST ANOTHER VIN
                            Branded Title
                            *The VIN information contained herein and information derived therefrom is the proprietary property of The Polk
                            Company and is to be used only for the purpose of warranty verification and shall not be used for any other
                            purpose whatsoever.
                            Vehicle has no current record of branded titles.
                            • John D.
                              • June 30, 1991
                              • 875
                              Re: 2013 corvette
                              It's the vehicle info from VIS...vehicle information system.... any dealer has access. Branded title NO is a good thing. A title gets branded when a vehicle is salvaged by the insurance company, scrapped or it's repurchased by the manufacturer from the ocnsumer....
