65' telescopic steering horn button - removal - NCRS Discussion Boards
  • David K.
    • September 30, 1992
    • 281
    My 65' telescopic horn button is not lined up correctly (needs to be turned a full quarter turn to the right for the Chevy 'bow tie' to be level). Does anyone know how to remove it for re-alignment ? Thanks !!
  • Keith B.
    • March 7, 2008
    • 928
    Re: 65' telescopic steering horn button - removal
    Gently pull it straight off.
    • Leo M.
      • May 31, 1995
      • 35
      David, both the 65 Shop Manual Supplement and the AIM show details of the telescoping wheel assembly. The Shop Manual Supplement provides step by step details, Section 9-3. Only special tool you will need is a wheel puller
      • Page C.
        • February 1, 1979
        • 802
        The 1965-66 tele horn button has 3 spring fingers on the underside that snap over the horn button stand. There is a plastic insulator between the locking ring and the horn button. The insulator should have one slot about 1/4 inch wide visible from the top. Find the slot and insert a very-very small screw driver or similar tool into it and pop out the horn button.
        • Don H.
          • December 1, 1981
          • 1491
          I thought the button was "keyed" to only go on one way - not 100% sure. Good luck, Don H.
          • Jim D.
            • 2885
            You are correct.
