90 Horn Problem - NCRS Discussion Boards
90 Horn Problem
  • E B.
    • March 1, 1978
    • 127
    90 Horn Problem
    Horn system on my 90 coupe stopped working from the buttons. IS THIS A COMMON PROBLEM AS jAMES White suggested in his post on the 1990 ZR-1 time capsule? I've already had the other usual problems with the car. NOTE, horns work with 12 vdc applied. thanks Ed Bauscher
    • 6960
    Re: 90 Horn Problem
    Ed cars with Air bags on the steering wheel do have clock spring problems sometimes. I don't have a wiring Dia.handy, generally at the base of the column the turn signal switch harness is located there, You'll need A Volt/ohm meter. find the correct colored wire and use the ohm meter to check for flow when hitting the horn button. sometimes if you take a 12volt test lamp and just touch each wire you'll come to the wire that operates the horn relay. and when you touch that wire the test lamp will act as a ground and the horn will beep.
    • E B.
      • March 1, 1978
      • 127
      Re: 90 Horn Problem
      Thanks Edward for the heads-up on the clock spring, I've had similar issues with other cars. 90 only has 44k miles but its still 23 years old. sincerely, Ed Bauscher
