340 SHP question - NCRS Discussion Boards
340 SHP question
  • William C.
    • May 31, 1975
    • 6037
    Re: 340 SHP question
    Originally posted by Jim Cear (34103)
    Thanks Bill, right now I am running a single wire electronic points set up. I wonder if a new/modern distributor cap with with a new rotor would make a difference?
    I will take this journey one step at a time and see if I find success . I sure hope I don't have a wiped out cam.
    I Can't comment as all my experience is with high-performance Point and standard ignitions systems, I'm of the old-fashoned "tricks are for Kids" thought pattern. I can work on a points car if it fails, and can look at the points to assess their condition. I can't do either with a "black Box" and I don't trust them as far as I can throw one (which is getting shorter every year as I age...)
    Bill Clupper #618
    • Loren L.
      • April 30, 1976
      • 4104
      Change out your fouled spark plugs.
      • John D.
        • December 1, 1979
        • 5507
        Jim, If you are using NOS or SR Delco Remy points and condenser you might want to replace those with NAPA ones. John
        • Jim C.
          • May 31, 2000
          • 96
          Secondaries always looked fully opened when pedal depressed in the garage . Today I disconnected both left and right choke actuation rods , the throttle body and secondary linkage from the choke then took it out for a run.
          WOW! It wound right up to 5000 rpm like it never had. I chickened out at 5000 grand and lifted.
          Now I have a 327 solid lifter engine. Amazing sound !
          thanks to all who posted suggestions for me. I will follow up on all as well. I even found a 60's vintage rotor cap on eBay!
          Now I have to figure the choke / secondary linkage fix.
          Happy Fathers Day to all!
          Jim Cear
          • Timothy B.
            • April 30, 1983
            • 5203
            Jim,
            Get a 1963 Corvette service manual and you will find a section outlining in detail the Carter AFB carburetor adjustments including the choke secondary lock out which sounds like the problem from your description.
