Courtesy/Dome light problems - NCRS Discussion Boards
  • Dennis O.
    • December 1, 1988
    • 438
    I am having a problem with the courtesy/dome lights in my '67 coupe. The courtesy lights don't work at all and the dome
    light is on all the time (I currently have the bulb removed). Everything I see looks good (jamb switches, etc.). I have
    checked the wiring diagram in the A.I.M. and the factory service manual and believe I understand how everything is supposed
    to work. There are a number of 20GA orange wires that feed power to the lights, and a number of white 20 GA wires coming
    from the lights that go to ground through the door jamb switches and the light switch to complete the circuit. According to
    the wiring diagram, these orange and white wires meet at their respective junctions somewhere. I have looked and cannot
    find these junctions. If I could, I believe I could troubleshoot this problem quite easily.
    My question is : Do these junctions actually exist somewhere behind the dash, or are they "virtual" junctions buried in the
    wiring harness somewhere? (This car has the original wiring harnesses). I'm sure someone has had one of these apart far
    enough to point me in the right direction.
  • Keith B.
    • March 7, 2008
    • 928
    Re: Courtesy/Dome light problems
    Your light switch is not turned the whole way to the right is it?
      Dennis -
      Do you have the correct #90 dual-contact bulbs in the courtesy and dome lamps? Using a similar single-contact bulb will cause all manner of shorts, blown fuses, and frustration.
      • Dennis O.
        • December 1, 1988
        • 438
        Thanks John, but I already checked them. How I wish it were that easy.
        • Dennis O.
          • December 1, 1988
          • 438
          WOW! You've got more guts than I do! My problem pales to insignificance. Seriously, are you done with that yet?
