What Automatic Transmission do you recommend for 54 Vette? - NCRS Discussion Boards
  • John C.
    • June 30, 1974
    • 2
    I have 54 that has been in family since new. I am confused by the ATF choices available. I would appreciate any recommendations for a specific product appropriate for the car.
  • John C.
    • June 30, 1974
    • 2
    Re: What Automatic Transmission do you recommend for 54 Vette?
    I meant automatic transmission fluid. Sorry for the senior moment
    • Ray G.
      • May 31, 1986
      • 1189
      John;
      I'll probably get criticized for this, but;
      We use Dexron VI (synthetic) in most everything GM. Have very good transmission life with it. We live, most of the year, in Phoenix, AZ. One of the the most brutal places for transmissions with 300 degree under hood temps.
      When you buy Dexron 6 by the case the price isn't to much more than than regular Dexron. Also you can mix 6 and regular Dexron.
      my .02
      I hope you dance
      • Philip C.
        • December 1, 1984
        • 1117
        Everyone has an opinion, mine I have used type F (Ford) in my 53 and all my other GM cars since the 70's never had any issue with it. Phil 8063
        • Dick W.
          • 10483
          I believe that most, if not all, fluids are backwards compatible. Type F would be appropriate for your car. I would avoid synthetic simply due to the propensity of synthetics to leak. Modern sealing technology works with synthetics but in 1954, the technology was woefully lacking
          Dick Whittington
          • Ray G.
            • May 31, 1986
            • 1189
            Hello;
            Synthetic oil received a bad rap early on because "seal swell" was at a different rate than organic oils.
            Formulas for synthetics were changed shortly after inception to address the situation.
            Maybe we can get Duke to chime in here.
            I hope you dance
