Glovebox Door Restoration - NCRS Discussion Boards
  • James S.
    • July 31, 1990
    • 126
    1967 Glovebox Door
    Can you recommend someone (even if it's yourself) who will install a new aluminum front without replacing the rivets; paint both the front and inside while not disturbing the original tire pressure label and reinstall the Corvette emblem?
    Thank you in advance to all who would recommend that it is an easy DIY project - have two doors to be restored and just do not have the time.
    Any referrals would be appreciated.
  • Steve B.
    • March 1, 2002
    • 1195
    Re: Glovebox Door Restoration
    Jim, check with Andy Cannizzo. I believe I overheard him say that he can do this.
    • James S.
      • July 31, 1990
      • 126
      Thank you Steve.
      Other recommendations also appreciated.
      • James S.
        • July 31, 1990
        • 126
        Thanks for all the PM's; Provider obtained.
        • Gerard F.
          • June 30, 2004
          • 3806
          James,
          See if your provider can provide an insert with a slight horizontal brush instead of a mat type finish.
          I appreciate judging with you, maybe I'm a little too picky on the insert finish.
          Jerry Fuccillo
          • James S.
            • July 31, 1990
            • 126
            Good to hear from you - agree on the brushed aluminum finish.
            We will use the insert available from LIC.
            Do you know of a vendor who can supply an insert with a more original finish?
            Originally posted by Gerard Fuccillo (42179)
            James,
