Air Cleaner 1959 - NCRS Discussion Boards
Air Cleaner 1959
  • John C.
    • September 30, 2001
    • 130
    Air Cleaner 1959
    My car is totally stock, I have the correct carb and air cleaner, but it never sat level on the carb, it is leaning a little forward not level, is that correct?
  • Terry D.
    • May 31, 1987
    • 2696
    Re: Air Cleaner 1959
    What is it hitting on to make it lean forward? Pictures would probably help. Is the carb sitting level?
    • John F.
      • March 23, 2008
      • 2415
      Is it rubbing up against the ignition shielding? Stock tires and wheels? Air shocks?
      • Dan B.
        • July 13, 2011
        • 545
        The bottom of the air cleaner has indentations for the WCFB carb (assume you are using the correct WCFB carb) and there is only 1 correct position for it to fit in relation to the choke and other moving parts. Take a look and see if that is your problem. Dan
