Quadrajet Lack of Stamp Question - NCRS Discussion Boards
  • Brad H.
    • January 27, 2009
    • 250
    I have a Q-jet that came with no stamped ID number. I believe it's an early 70's carb. It is a Carter built Q-jet and does not have the round embossed tag either as on early units. Were the non-stamped carbs service replacements? Seems like they should at least have an ID stamp but this one is totally as cast with no ID stamping at all.
    thanks,
    Brad
    • 11692
    Re: Quadrajet Lack of Stamp Question
    Brad,
    How about some photos?
    Patrick
    • Brad H.
      • January 27, 2009
      • 250
      I'll work on some pics. I thought this might be a fairly common occurrence. The normal location for the ID stamping has not bee ground on and looks to be as manufactured with the standard greenish gold colored casting.
      • Lyndon S.
        • April 30, 1988
        • 1027
        Could be a service body some times the main body was left blank on these as I was once told by a restamper of Q- jets.
        • Jeff P.
          • 799
          My Q Jet also has no stampings. I have the correct date on the bottom plate but nothing on the body.
          68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
          2014 Arctic White Z51 Vert. (Wifes)
            • 15634
            Date on the base plate is correct for 1968 and maybe early 1969, but those Q-Jets usually (TFP) have the number and broadcast code stamped on the main body if the main body is original to the car.
