I was wondering if anyone has used Rustoleum Chevy Orange engine paint. The car will not be judged, so I'm not so concerned if it's a shade off. The paint is rated at 500 degrees, and I want to make sure that most of it will burn off the exhaust manifolds. On the other hand, if the car is not going to be judged, what might be a more practical solution?
Exhaust Manifold Paint
Re: Exhaust Manifold Paint
Don,
You might consider sending them to Jerry MacNeish. He puts a thin coat of aluminum on them so they don't rust again on the outside. He supplies high temperature spray paint. You paint them once they come back. Here's the link:
Joe- Top
Thanks. I'm still thinking that maybe I should be using a Chevy Orange. The car is a 64 300 HP, but as I said in my original thread, I don't plan on having the car judged, just thought it would be nice if it looked mostly correct.- Top
I assume you are going for the correct look. Prior to somewhere around mid '66 the exhaust manifolds were assembled to the small block engine prior to painting. So they would have a good amount or orange paint on them. But as ya know it burns off in the center section of the exhaust manifold. After that time frame, late '66 and '67 small block exhaust manifolds were not assembled till after engine paint. So those exhaust manifolds should be raw cast look. But most of us do not like rust, so a high temperature cast blast paint imitates the raw look. Be advised the blast paint finish or any other application on late '66 and '67 small block exhaust manifolds will not pass NCRS judging.
I prefer VTH high temp cast iron paint over other finishes, as it does not destroy the original manifolds as you can bead blast it off any time you decide to not sacrifice NCRS points. But for anybody driving your Corvette it keeps a neat appearance. Price is cheap too, less than $10 a can.- Top
Gene,
You are correct, I was thinking of going for the correct look on a 1964 small block. If I do, and use the VHT Chevy orange, then I have two questions. 1. Should I use the VHT high temp which is rated at 1300-2000 degrees? or 2. Should I use the engine paint rated at 650 degrees? The reason for the question is if you are looking for an original look, will the high temp burn off like the original factory paint and just leave some on the cooler ends of the manifold.
As you can tell, I am on the horns of a dilemma, because I must admit, I prefer the raw cast look, even though this is for a 64 small block. After all of my questions, if I do chose the raw cast look, do I paint everything with the VTH high temp cast iron paint, i.e. the bolts, french locks, etc.? Thanks for your input.- Top
Gene,
Generally the orange if sprayed in the center portion of the manifolds turns black. This is also true on the intake were the heat passages are in the center.- Top
I understand your questions, I just went through this on my '64 300HP vette. I do drive my car some and not surre if I will have it judged, but I like to make it as original as practical (what ever that means). Upon the recommendations of some of our local members, I use Eastwood's Stainless Steel High Temp coating. I did mine last winter and it does not have to many miles on it yet, but I saw a '58 that is several years old and it a Top Flight car. This may not have the correct look but I expect it to last an look good. I bead blasted it first and coated my side exhaust system with this.
I added photo.Attached Files- Top
Hi Dale, nice engine details. You might want to shorten your tee hose and route the hoses over the top of your battery away from the exhaust manifolds. Check out some pictures of original routings etc.
Dan1964 Red FI Coupe, DUNTOV '09
Drove the 64 over 5000 miles to three Regionals and the San Jose National, one dust storm and 40 lbs of bugs!- Top
Don, Here are some more pictures. I decided to use this Stainless Steel High Temp Coating for drive-ability and lasting effects. I have considered applying some engine orange over spray to make more original. I did not paint my bolts or french locks. I noticed from my pictures that I missed bending over one of my french locks (thanks). I am inserting a link to my pictures. I hope this will provide them in more detail as I had to reduce the resolution to up-load them to here. You should be able to just click on my link or copy and paste it into you WEB browser.
I am considering having my car judged to to see everything they detect and for my own knowledge. I likely may not make Top Flight, but its my driver and cruse-ins. Good Luck on your project.- Top
