Re: Exhaust Manifold Paint
Dan, Thanks for the information, great suggestion. I have a good friend here with a mostly original that I use to verify my car. I will check that out. This would be an easy fix. I am having issues with my overflow tank, it has some pin hole leaks. Mostly on the bottom nipple. Someone has welded the nipples, but it seems to be the original for my car. I used some JB Weld and it seems to be holding pressure. I am also looking at raditors, mine has been replaced and it has a small leak. I am checking out the Dewitt's. Again, Thanks.
