Fuel Pump Pressure - NCRS Discussion Boards
Fuel Pump Pressure
  • Al P.
    • February 15, 2011
    • 87
    Fuel Pump Pressure
    What should the normal fuel pressure be in PSI for mechanical pump?
    I run a Carter mech pump on my BB and it runs at 7lbs PSI.
    Thanks All.
  • Timothy B.
    • April 30, 1983
    • 5203
    Re: Fuel Pump Pressure
    Al,
    Somewhere between 5 and 6 PSI. If the pressure get too high there is a chance the needle and seat could be over come but 7 is probably OK. I don't know if a big block pump carries higher pressure I doubt it but my figures are for a small block pump.
    • Al P.
      • February 15, 2011
      • 87
      Thank You Tim
