C2 "light: indicator 1965 Conv - NCRS Discussion Boards
  • Stephen H.
    • December 20, 2012
    • 10
    Headlight door "light" indicator never worked so during restoration we checked and changed bulbs everywhere. Now when the light pods are closed completely and lights on, the indicator is OFF. As the pods roll open "light" comes on and stays on while lights are on. That is opposite of what owners manual says??? We did nothing to the lights but did have the dash out. What do we have backwards?
  • Gene M.
    • April 1, 1985
    • 4232
    Re: C2 "light: indicator 1965 Conv
    Steve,
    Something is backwards. It sounds like the two headlight indicator switches are not adjusted correctly. The "Y" yoke screw should be triggering the switch plunger. Sounds like this is not happening or the switch or possibly both switches is bad. Check out only switches (isolate them by unplugging blue vinyl terminated wired) separately with a meter for making and breaking contact with light doors closed and open. Did you replace the head light switch? Repro? New dash harness? The AIM has a wiring diagram with details on connections at the head light switch. I suggest you look there first. Make sure wire colors are terminated per AIM diagram.
    • Bob R.
      • June 30, 2002
      • 1595
      Did you install the proper bulb? The correct bulb flashes when operating.
      • Edward J.
        • September 15, 2008
        • 6950
        Steve, is it possible that the Y-yokes for left and right are installed on the wrong sides, or reversed, maybe Gene can comment.(wild guess)
        • Gene M.
          • April 1, 1985
          • 4232
          Ed,
          It is possible to put the yokes on backwards, but the buckets would not rotate much. The yokes on both sides are common part, no RH & LH. Problem has to be electrical if switches check out and screw head is contacting plunger.
          • Stephen H.
            • December 20, 2012
            • 10
            Thanks for the help. I pulled the light switch out. Harness looks to be original. Harness shows heat signs at post #3 yet no wire there??? The 3 -5 post have copper jumper on switch. Checking diagram and working my way forward. Something fishy as all interior light socets were empty when we started on car. They worked fine with old switch but not the new repop, ie new problem. "Light" indicator still backwards. Spend the day on it.
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11334
              I had the exact same problem on a '63. Dash indicator worked reversed of the intended design. Warning light would only be powered when the buckets were in the full up position with headlights on.
              Much electric troubleshooting with no problems found......then I referenced the photo in the service manual and saw the switches were not in the same physical position as on the car. When properly mounted, the switches angle (upwards) and towards the front of the nose(ref 2nd pic below). Mine were angled (downwards) and towards the rear of the car.
              The inner pivot support housings(1st pic) for the buckets were reversed. Whoever reinstalled them before I got the car had swapped the left and right housings. When this is done, it repositions the switch and the stop mechanisms, completely reversing the operation of the telltale dash light limit switches.
              The housings are marked L & R, but IIRC you cannot see them when installed.
              Last edited by Richard M.; May 4, 2013, 09:22 AM. Reason: added "(upwards)" and "(downwards) "
              • Stephen H.
                • December 20, 2012
                • 10
                Thanks Richard, will check that. Car assembled so this is going to be exciting. Also missing the DG16 wire from post 3 of the light switch to the fuse box. Wonder what that does?
                • Richard M.
                  Super Moderator
                  • August 31, 1988
                  • 11334
                  DG16 is the feed to the fuse for the dash indicator lights, powered when park or headlights are on. After the fuse the wires are gray.
