Do I gap this 68 door gap? - NCRS Discussion Boards
  • Patrick N.
    • March 10, 2008
    • 954
    I thought I would toss this out there for some opinions. From what I understand this is fairly typical 68 production quality. If so, would you make the gap consistent?
  • Michael G.
    • January 1, 1997
    • 1251
    Re: Do I gap this 68 door gap?
    I've seen this gap quality on numerous shark cars....not just '68's. I've owned 2 sharks both had inconsistant gaps. I left mine alone, that's the way they were built.
    • Henry J.
      • November 1, 1999
      • 457
      My 68 has this gap on both sides. After I realized this was a relatively common original flaw, it was a relief. I left mine alone.
      • Ralph S.
        • February 1, 1985
        • 935
        Was the front upper surround panel replaced.
        • Jack C.
          • September 30, 1992
          • 1090
          Patrick. Here's a good shot of mine to reference. I see yours is an earlier car as well.
          Jack Corso
          1972 Elkhart Green LT-1 Coupe 43,200 miles
          Top Flight 1994, 2018 & 2021
          • Patrick N.
            • March 10, 2008
            • 954
            does not appear to be - but some work was done to the lower portion of the nose - frame also needed aligned so some banging occurred in the life of this car.
            • Patrick N.
              • March 10, 2008
              • 954
              Thanks Jack- one thing I notice on your car is how the painted window trim piece tip is almost perfectly lined up with the corner tip on the fiber glass. My pic has the two off by a good 1/4" or so.
              • Henry J.
                • November 1, 1999
                • 457
                Ralph:
                We had the entire car down to bare fiberglass for a re-paint. There was no evidence of the top surround having been replaced, but you make a good point.
                • Larry E.
                  • 1680
                  Just for comparison to Jack's car; here is my "late" 68. Note the difference in the fender caps and set-back mirror. LarryBloomington Gold 2006 - 1968 Corvette 003.jpg
                  Larry
                  LT1 in a 1LE -- One of 134
                  • Larry E.
                    • 1680
                    Originally posted by Larry Evoskis (16324)
                    Just for comparison to Jack's car; here is my "late" 68. Note the difference in the fender caps and set-back mirror. Larry[ATTACH=CONFIG]46312[/ATTACH]
                    Sorry for the bottom picture; must be same file number; unkown how to take the picture off--Thanks; Larry
                    Larry
                    • Dick W.
                      • 10483
                      Fixed it fer ya
                      Dick Whittington
