63 FI Distributor Shield Rivets - NCRS Discussion Boards
  • Michael G.
    • November 12, 2008
    • 2157
    Re: 63 FI Distributor Shield Rivets
    Thanks, John, good info
    OK, Mikey,....no problem
    Mike
    • James W.
      • December 1, 1990
      • 2658
      Originally posted by Dan Holstein (1440)
      Jerry Fuccillo made a setting tool that works fine, used on my 64 top shield front grounding clip.
      Dan
      Any chance of someone finding out what Jerry Fuccillo's rivet setting tool looks like? I need to replace the ground clip on two ignition shields, one big block and one smaal block.
      James West
      • Dan H.
        • July 31, 1977
        • 1369
        James West
        James, there's a link at the bottom of this tech session. Front clips, has Jerry's info etc.
        Dan
        1964 Red FI Coupe, DUNTOV '09
        • Michael G.
          • November 12, 2008
          • 2157
          Well, I now have 100 zinc plated rivets. Very magnetic. They look good. Too good. Like chrome. Thinking about just putting them in, as is, without changing to chrome plating. Unfortunately our crack judges (some of whom are reading this thread and have asked for samples) will now be aware of my laziness and therefore, will not be fooled by my faux chrome, thus will proceed to deduct for rivet plating in July. So, we will have a delay while we send these to my plater, who, by the way thinks I'm nuts for chrome plating rivets....oh well
          Mike
          • John D.
            • December 1, 1979
            • 5507
            Mike, Now I know you won't do this but if you polish the zinc heads on your buffing wheel they will shine just like chrome in a second. But you have gone this far so do it right. JD
            • Michael G.
              • November 12, 2008
              • 2157
              OK, I'm about to start practicing rivet installation. I need to know what a typical installation looked like. The photo below is a collapsed rivet from a repop shield I have. Is this similar to the way originals looked? Thanks
              Mike
              • Alan D.
                • January 1, 2005
                • 2039
                Here is an original from an early 65 (may be sooner however nobody knows)
                The diameter of the washer (what appears to be anyways) is 0.356"
                • Michael G.
                  • November 12, 2008
                  • 2157
                  Thanks Alan, those look pretty much like the repro ones I have.
                  Mike
