1969 Stamp Pad - NCRS Discussion Boards
1969 Stamp Pad
  • Roger G.
    • October 11, 2012
    • 268
    1969 Stamp Pad
    My block is back from a rebuild, and this is a picture of the stamp pad. The builder said he cleaned the pad with a scotch brite pad, then taped it for painting. Here is a photo. It looks like the broach marks are ok, but there are some surface scratches there, maybe from the cleaning or tape removal. Also, the last digit in the VIN, I'm not sure why it looks smooth around the perimeter of the number, maybe some light sanding was done?
  • Mark D.
    1984-86 Team Leader
    • June 30, 1988
    • 2152
    Re: 1969 Stamp Pad
    It's unfortunate that the rebuilder did that but, you'll be fine during judging.
    Kramden
    • Michael G.
      • January 1, 1997
      • 1251
      Re: 1969 Stamp Pad
      What's does the suffix read?
      • Jack H.
        • April 1, 1990
        • 9906
        Re: 1969 Stamp Pad
        Two comments: (1) Remember when the car is judged ONLY the originality side of the ledger is considered on the stamp pad--NOT condition and (2) consider using a tooth brush and paint remover on the Chevy orange that's down inside the stamped characters. On the first, some judges see scratches and presume they're the result of improper broaching vs. simple age + wear and tear. On the second, do it NOW before the engine has undergone heat/cool cycles and the paint is firmly set up.
        • Roger G.
          • October 11, 2012
          • 268
          Re: 1969 Stamp Pad
          Thanks.... That was my concern
          • Roger G.
            • October 11, 2012
            • 268
            Re: 1969 Stamp Pad
            Thanks Jack ....is the residual paint a cosmetic or judging issue? Also it was suggested that the pad could be aged... What is this?
            • Joe R.
              • May 31, 2006
              • 1822
              Re: 1969 Stamp Pad
              Roger,
              Paint on the pad is a judging issue. The judging guide will say that the pad should be paint free.
              Joe
              • Dick W.
                • 10483
                Re: 1969 Stamp Pad
                I would not worry about it from what I can see. Paint is not a judging issue as it does not obscure surface or characters. Looks a lot better than many we have seen.
                Dick Whittington
                • Paul J.
                  • September 9, 2008
                  • 2091
                  Re: 1969 Stamp Pad
                  I thought that a little bit of paint inside the characters was TFP.
                    • 15601
                    Re: 1969 Stamp Pad
                    Not if the line workers followed instructions.
                    • Patrick B.
                      • August 31, 1985
                      • 1996
                      Re: 1969 Stamp Pad
                      Wasn't the engine painted after the Tonawanda stamp?
                      • George W.
                        • July 31, 1998
                        • 322
                        Re: 1969 Stamp Pad
                        You can get the red out of the letters with a Q-tip and paint remover...with care.
                        Dr. George
                          • 15601
                          Re: 1969 Stamp Pad
                          Certainly, and the instructions to the paint line were to cover that area to be free from paint.
                          Someone once posted a picture of the fixture that was used to cover that area during painting, but I can't remember if it was for Flint or Tonawanda -- but the results were supposed to be the same for each plant. Once the engines were painted blue the procedure changed, but that is another story.
