Question on Quadrajet Bolts - NCRS Discussion Boards
+ More Options
Posts
  • Larry E.
    • 1702
    We know the quadrajet bolts (to secure to I/M) consisted on two long bolts in
    front and two studs on back on I/M on the L36 in 1968. Where the other engines
    (even on cast iron I/M) secured the same way or did they have two smaller bolts
    in the back insted of studs? When did Chevrolet switch over to all bolts insted
    of a combination of bolts and studs? Thanks in advace. Larry
    Larry
    LT1 in a 1LE -- One of 134
    • 43287
    Re: Question on Quadrajet Bolts
    Larry-----
    All 1968-71 engines with Q-Jets used the same bolts-front, studs-rear carburetor attachment. Things changed to all bolts for the 1972 model year and thereafter
      • 15640
      Larry-----
      All 1968-71 engines with Q-Jets used the same bolts-front, studs-rear carburetor attachment. Things changed to all bolts for the 1972 model year and thereafter[/QUOTE]
      Here you go: The first photo is a 1970 Q-jet and the second is a 1972.
      BTW: You will not get either the front bolts or the rear nuts at you local hardware store.
        • 43287
        Larry-----
        BTW: You will not get either the front bolts or the rear nuts at you local hardware store.[/QUOTE]
        Terry-----
        I think it was a dumb thing to replace the studs with bolts. The studs help to easily locate and position the gasket, heat shield and carburetor.
          • 15640
          [ATTACH=CONFIG]46118[/ATTACH][ATTACH=CONFIG]46117[/ATTACH]
          Terry-----
          I think it was a dumb thing to replace the studs with bolts. The studs help to easily locate and position the gasket, heat shield and carburetor.[/QUOTE]
          Joe,
          From our perspective it sure was. Want to bet the bolts (as installed) cost less than the studs and nuts?
          • Jeff P.
            • 799
            Not to get off the subject ,Terry I noticed the thermostat housing has a stud and nut on the passenger side. I've never seen it on a 68. Should they be set up like that?
            68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
            2014 Arctic White Z51 Vert. (Wifes)
              • 15640
              Neither of those pictures is of a 1968. There is a good chance there is no stud on 1968 due to the different accessory drive mounting system. That stud had no Corvette application, and the applications that used it were, I think, later than 1968. This is just another of those wonderful 1968 features.
                You betcha - bolts are always less costly than studs and nuts.
