'61 tachometer problems - NCRS Discussion Boards
+ More Options
Posts
  • Mike B.
    • August 14, 2011
    • 61
    1961 270 hp w/ 2x4's have both tach and speedo needles bouncing heavily. Had speedo overhauled and now works. Had tach sent back to where last restored (before I owned car) they verified that tack was ok just needed new cable. did that and bounce stopped. BUT, after install now it registers about twice what I am doing as compared with my timing light and also dwell meter/tach combo. I understand they were not the most correct tach even when new. At idle timing light shows 900 and tach shows 2000. Obviously the engine is not doing 2000. What I do not know is whether or not I have the right generator in the car (has been replaced sometime in the past) and or pulley for that matter. For what it is worth I was going to put a new belt on the car as I was restoring it and the belt with correct number was too long and could not tighten properly so I continue to use the belt that was on it. Looking back that tells me that it could be that the pulley is too small therefore turning too fast and making tach register too fast. I looked at the generator drive mechanism on back of generator and it looks ok. I looked in parts catalogs and both Zip and Paragon show a pulley but not for F.I. or high lift cams. Is there a special generator and/or pulley for 270 hp w/ 2x4"s? Or am I overlooking something else?
  • Terry D.
    • May 31, 1987
    • 2696
    Re: '61 tachometer problems
    What size is the pulley? If memory serves me right standard pulley is 3&5/8 and high horse pulley is 4&1/8. Pulley would have to be really small to double the rpm on tach. Sounds like you have the wrong tach. Someone with more knowledge of generator driven tachs will chime in hopefully.
    • Mike E.
      • February 28, 1975
      • 5139
      If double, it's probably calibrated for distributor drive instead of generator drive. Distributor drive is calibrated twice cable speed, generator is calibrated cable speed.
      • William C.
        • May 31, 1975
        • 6037
        Should be ink stamped on the outside of the tach housing "reads cable speed" or "reads twice cable speed"
        Bill Clupper #618
        • Mike B.
          • August 14, 2011
          • 61
          seems to be a general consensus that the tach may be for '62 distributor driven, that is not what I wanted to hear after getting it all back together. Hoping for generator issues cause it is easier to fix than pulling cluster again. thanks to all for input this far. Mike
          • Mike B.
            • August 14, 2011
            • 61
            I decided to measure the pulley and it is only 3 1/8 diameter which explains my belt issues that I mentioned at the beginning of post. So first thing is to locate correct pulley. back to part 2 of problem is the 3 5/8 pulley correct for the 270 2x4's set up and if not who sells the larger 4" pulley cause they are not listed in parts books that I have seen. any and all help is greatly appreciated. thanks, Mike
            • Robert S.
              • May 31, 1988
              • 81
              When I had my 60 tach cleaned and oiled several years ago, the guy completed the work and told me one of the magnets was missing. He replaced it and as a result the tach read double cable speed. You might see if your tach guy replaced a missing magnet. If so, then the fix is to remove it.
              • Mike B.
                • August 14, 2011
                • 61
                thanks, and I have an email into them to check on history of repairs.
                • Terry D.
                  • May 31, 1987
                  • 2696
                  According to the Judging Manual all 61 except 315hp use a 3 and 5/8 pulley. Most Corvette venders have this and I'm sure some of us have one laying around. I'll check tonite when I get home.
                  • Mike B.
                    • August 14, 2011
                    • 61
                    thank you and yes I do see that size listed in the books. If you or anyone has an extra I would be happy to purchase it. Thanks again, Mike
