Small block pulley question. - NCRS Discussion Boards
  • Bruce B.
    • May 31, 1996
    • 2930
    Can someone provide me the dimension between the center of the crankshaft to the center of the water pump shaft?
    The engine is a 64 327 with a stock water pump(short pump).
    Thanks.
    • 43248
    Re: Small bolck pulley question.
    Thanks.
    Bruce-----
    The dimension you seek is 7.04" and is the same for all Gen I small blocks.
    • Bruce B.
      • May 31, 1996
      • 2930
      Joe,
      Thanks.
      So with the 7.04" dimension, in theory I should be able to use 7.00" dia. pulleys if they are truly 7.00".
      • Terry D.
        • May 31, 1987
        • 2696
        Bruce A 7" diameter pulley will only be half way to the center of the water pump. Remember the other half of that 7 inches will be below the crankshaft. High hp pulleys are 8" in diameter.
          • 43248
          Joe,
          Thanks.
          Bruce------
          Yes, as long as BOTH the balancer and waterpump pulleys are 7" or less in MEASURED OD, it should work.
          • Bruce B.
            • May 31, 1996
            • 2930
            Thanks.
            I got a set installed.
