1968 carpet question - NCRS Discussion Boards
  • Russ S.
    • April 6, 2010
    • 134
    The AIM shows that the carpet for the front has a flap cut for the front seat mounting bolt and also flaps cut for the rear seat mounting bolt. Can someone confirm that the rear flaps were actually used and that a hole was not just made in the carpet. Anyone with original 68 carpet?
    thanks
  • John C.
    • January 1, 2005
    • 616
    Re: 1968 carpet question
    Russ
    I'm 99% sure my car has it original carpet. On my 68 I have flaps cut in the front but not in the back. The bolt simply goes through the carpet in the rear.
    John
    • Jack C.
      • September 30, 1992
      • 1090
      My 68 #9643 with original carpets has cutouts in the front and back.
      Jack Corso
      1972 Elkhart Green LT-1 Coupe 43,200 miles
      Top Flight 1994, 2018 & 2021
      • Russ S.
        • April 6, 2010
        • 134
        Are the rear cutouts like the ones in the AIM that are H-shaped so they cover both sides of each mounting bracket?
        • Jack C.
          • 1090
          Pass rear right side.
          Pass rear left side.
          Jack Corso
          • Rich G.
            • August 31, 2002
            • 1405
            My July built 68 Coupe with original carpet looks exactly like the pictures Jack posted.
            Rich G
            • Russ S.
              • April 6, 2010
              • 134
              Thanks. The pictures help. It generally looks like the AIM drawing. I see the you have the seat belt guides in the carpet. Could you post a picture of them so I can confirm the general location and spacing relative to the seat and door sill.
              • Jack C.
                • 1090
                Will do later tormorrow.
                Jack Corso
                • Jack C.
                  • 1090
                  Here you go.
                  Jack Corso
                  • Russ S.
                    • April 6, 2010
                    • 134
                    Thanks. That should help me.
