72 Vapor Canister - NCRS Discussion Boards
72 Vapor Canister
  • John W.
    • February 1, 2006
    • 16
    72 Vapor Canister
    Can't find a new vapor canister. Read where people have cut open the old canister and replaced the old material with activated charcoal purchased from the pet store. Is this a valid fix? Also noticed a diaphragm at the top of the canister under a cap where the hoses connect to the canister and go up to the carburetor. That 40 year old part has to be bad. Is a replacement available?
  • Paul Y.
    • September 30, 1982
    • 570
    Re: 72 Vapor Canister
    I found new parts and complete canisters for my 71 from Dr. Rebuild a few years back. I got NOS GM stuff from him at a good price also. It is amazing to me what he still has NOS. I would give him a try if I were you. Paul
    It's a good life!
    • Dick W.
      • 10483
      If my memory serves me correctly, there is a replaceable charcoal filter in the bottom of the cannister
      Dick Whittington
      • Bob D.
        NCRS Shipping Data Report Manager
        • April 30, 1996
        • 795
        I bought several replacement filter elements from the Dr. Rebuild several years ago. Don't know if he still has them but cn't hurt to call.
        Bob
        • Dick W.
          • 10483
          Bob
          No need to go to a Corvette parts vendor here. Wix 42998, or AC A478C Any parts store can cross that number
          Dick Whittington
          • Michael W.
            • April 1, 1997
            • 4290
            Why are you replacing it?
              • 6956
              John, is the vacuum line from the canister to carb. have raw fuel inside the line? This would indicate that the diaphram on canister has failed.
              • John W.
                • February 1, 2006
                • 16
                Tried them already - no longer have the part. Thanks for the reply
                • John W.
                  • February 1, 2006
                  • 16
                  That filter at the base of the canister is still available - made of a material similar to foam. It is the contents of the canister that i am interested in replacing. The canister is original and the car has been idle for 25 years. I can't imagine that the 40 year old material on the inside is still functional.
                    • 43273
                    John-----
                    The last available canister assembly for your application was GM #17063011, aka Delco #215-12. It's configuration was a little different than the original but it was 100% functional. Unfortunately, it was fairly recently discontinued. There might still be a few around, though.
                    • John W.
                      • February 1, 2006
                      • 16
                      The reason I was planning on replacing it is because I am assuming that it is so old that it is no longer functional - I could be wrong. The car has not been run in 25 years. Doing a body off restoration and planned on replacing the part if I could find it. Same is true with the diaphram at the top of the canister - I know they don't last forever in a small gas engine carburetor. Do not trust it's functionality after 40 years.
                      • John W.
                        • February 1, 2006
                        • 16
                        Thanks for reply - searched the 17063011 number and found nothing - will try Delco 215-12. Would you assume, as I have, that my original part would no longer function properly?
                          • 43273
                          John------
                          Not necessarily. These things are fairly simple.
                            • 6956
                            John, the canister in my 72 is still the original. and no problems, If you want to remove it and check the vacuum diaphram it can be tested with a vacuum pump. thats really the only part that generally fails, The charcoal inside the canister is not a servicible part as far as I know. but generally I really don't think you'll see any problems, I have seen a post awhile back that when the charcoal inside the canister is found at the rear of the gas tank area where theres a plastic square resevoir above the tank then its gone. personally I have never seen it.
                              • 15631
                              Ed,
                              I seem to remember replaceable a yellow fiberglass filter at the bottom of the canister on some years. That may not be 1972 or even Corvette, but some canisters had it.
