More on the '60 FI problems - NCRS Discussion Boards
+ More Options
Posts
  • William C.
    • May 31, 1975
    • 6037
    #31
    Re: More on the '60 FI problems
    The wires vary by length, so try to keep 2000-3000 ohms per foot of length max. As to the rotor, I generally carry around an "old timer" and check for NORS items or look at some from Accel and similar high-perf outfits.
    Bill Clupper #618
    • Charles M.
      • November 1, 1979
      • 33
      #32
      George, IIRC there is a bushing pressed in the upper housing that can be adjusted to eliminate that up and down play. Pull out your mainshaft and press bushing up in housing.
      Chuck M.
      • George W.
        • May 31, 2000
        • 544
        #33
        Okay, some good news.
        Installed another 914 distributor and things are much better-----starts hot and cold, idles hot and cold, does not "break-up" at any rpm during test drives, and pulls/runs pretty good through all RPM ranges and WOT. Not perfect, but much, much better.
        Working on distributor "dial-in" procedures now(Duke's article)
        Thinking that next step is some Dyno time to find best air/fuel ratios through all rpm ranges under load. I will likely need some guidance in order to have a good Dyno session.
        Once again, many, many thanks to all who have been so generous with their time and knowledge.
        Cautiously optimistic,
        George Wright
