Lifting body off frame suggestions - NCRS Discussion Boards
  • Jim D.
    • 2885
    Re: Lifting body off frame suggestions
    I used my 4 post lift to lift the body off the frame. Simple,1 man operation. I had to put blocks under the posts to be sure it went high enough because I didn't want to remove the gas tank or tires first. If you removed the tank, it wouldn't be necessary.
    • Jim D.
      • 2885
      And putting the body back on.
      • Doug L.
        • March 14, 2010
        • 442
        #18
        Bob,Send a private message to me with your e-mail address. I will send the photo in larger format.Doug
        • Mike E.
          • June 24, 2012
          • 920
          #19
          Jim,
          Nice setup....Did you have any issues getting the doors back on and aligned properly without chipping the paint? That's want conserns me most about installing the doors after painting on coupe. Lacquer chips so easy.
          Mike
          • Jim D.
            • 2885
            #20
            Originally posted by Mike Eby (55078)
            Jim,
            Nice setup....Did you have any issues getting the doors back on and aligned properly without chipping the paint? That's want conserns me most about installing the doors after painting. Lacquer chips so easy.
            Mike
            No problem what-so-ever. Everything lined up perfectly. I've been doing it this way for many, many years.
            • Doug L.
              • March 14, 2010
              • 442
              #21
              Bob, Check your private messages. Couldn't e-mail you.
