Had this blueprint sent to me in an email and wondering how we can state 1963/4 Corvettes should be using "326" pump, when this ORIGINAL DRAWING for the "326" is dated 5-18-65, as indicated in the "cropped" first picture
Question on 326 Pump - Blueprint
Re: Question on 326 Pump - Blueprint
I've seen the blueprint previously. What you are saying is what I've been saying for yearsIn Appreciation of John Hinckley- Top
Bob,
Don't know what is happening? I see the print fine.....................Maybe I need to send to someone else to post, as obviously I don't know how to post here................Rick Aleshire
2016 Ebony C7R Z06 "ROSA"- Top
Rick -
Pics show up fine for me. We've run this one into the ground for years, but nobody in charge of the '63-'64 JG wants to accept the fact that the 326 pump didn't exist until 1965; they've carried that myth forward AGAIN, into the new 6th Edition.- Top
John,
Thank you! Guess I have had my head in the sand and missed all the previous discussions. So, when I received the email, I just had to post and see what people had to say. Guess everyone believes the myth and we continue to have the wrong water pumps attributed to the 1963/4's!Rick Aleshire
Here's the first pic loaded directly
3859326 w pump pic 002.jpg- Top
Not to bust anybody's bubble but this (from what I can see, bad photo) looks to be a machining drawing not a casting drawing. A casting drawing would have more dimensions describing the casting walls, draft, casting wall thickness and outline.
Back in the day the practice was to have a raw casting drawing and another drawing taking that casting and defining the machining dimensions.
This could also just be an inspection drawing.- Top
Dick Whittington- Top
Was it possible to see a 326 not dated in 65. I hope you see what I am trying to explain. Thanks EdNew England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
A lot of people use the 609 pump for 63/4. I understand the drawing and the date of the drawing but I do believe there are some original examples out there with 326 pumps. One other thing to add to the discussion, the guys who rebuild a bunch of these pumps have an opinion similar to what the judging guide states. Do we have any surveys of original cars and the pump casting numbers??- Top
