Question on 326 Pump - Blueprint - NCRS Discussion Boards
  • Rick A.
    • July 31, 2002
    • 2147
    Had this blueprint sent to me in an email and wondering how we can state 1963/4 Corvettes should be using "326" pump, when this ORIGINAL DRAWING for the "326" is dated 5-18-65, as indicated in the "cropped" first picture
    Rick Aleshire
    2016 Ebony C7R Z06 "ROSA"
  • William C.
    • May 31, 1975
    • 6037
    Re: Question on 326 Pump - Blueprint
    Rick, no picture attached?
    Bill Clupper #618
    • Rick A.
      • July 31, 2002
      • 2147
      I posted it DIRECT into the text box
      Rick Aleshire
        • 43219
        Rick-----
        I've seen the blueprint previously. What you are saying is what I've been saying for years
        • Bob J.
          • December 1, 1977
          • 714
          Rick, I get the red X.
          Are others seeing the print pics?
          Bob
          • Rick A.
            • July 31, 2002
            • 2147
            Bob,
            Don't know what is happening? I see the print fine.....................Maybe I need to send to someone else to post, as obviously I don't know how to post here................
            Rick Aleshire
              Rick -
              Pics show up fine for me. We've run this one into the ground for years, but nobody in charge of the '63-'64 JG wants to accept the fact that the 326 pump didn't exist until 1965; they've carried that myth forward AGAIN, into the new 6th Edition.
              • Rick A.
                • July 31, 2002
                • 2147
                John,
                Thank you! Guess I have had my head in the sand and missed all the previous discussions. So, when I received the email, I just had to post and see what people had to say. Guess everyone believes the myth and we continue to have the wrong water pumps attributed to the 1963/4's!
                Rick Aleshire
                • Michael W.
                  • April 1, 1997
                  • 4290
                  Here's the first pic loaded directly
                  • Michael W.
                    • April 1, 1997
                    • 4290
                    and the second
                    • Roy S.
                      Past National Judging Chairman
                      • July 31, 1979
                      • 1025
                      I'll bite guys, if the 326 is the wrong pump and everyone knows that, what is the correct pump?
                      • Gene M.
                        • April 1, 1985
                        • 4232
                        Not to bust anybody's bubble but this (from what I can see, bad photo) looks to be a machining drawing not a casting drawing. A casting drawing would have more dimensions describing the casting walls, draft, casting wall thickness and outline.
                        Back in the day the practice was to have a raw casting drawing and another drawing taking that casting and defining the machining dimensions.
                        This could also just be an inspection drawing.
                        • Dick W.
                          • 10483
                          Rick -
                          Again into the book of fables and fairy tales?
                          Dick Whittington
                            • 6942
                            Rick -
                            John, When did the dating of water pumps start for Corvettes ? The reason I am asking is the 326 pump I have on my SHP engine is not dated, Was the 326 pump used on other GM lines before they went onto corvettes in 65 ? It would seem by that time line corvette pumps would be dated.The drawing is dated 65.
                            Was it possible to see a 326 not dated in 65. I hope you see what I am trying to explain. Thanks Ed
                            • Joseph S.
                              • March 1, 1985
                              • 866
                              A lot of people use the 609 pump for 63/4. I understand the drawing and the date of the drawing but I do believe there are some original examples out there with 326 pumps. One other thing to add to the discussion, the guys who rebuild a bunch of these pumps have an opinion similar to what the judging guide states. Do we have any surveys of original cars and the pump casting numbers??
