1970 AM/FM Radio/ Stereo - NCRS Discussion Boards
  • David S.
    • August 9, 2009
    • 595
    Hi All,
    I'm interested in seeing pictures of a regular AM/FM Radio as well as the option AM/FM Stereo for a 1970 Corvette. Reference pictures of the face would be great.
    Dave
  • David L.
    • July 31, 1980
    • 3310
    Re: 1970 AM/FM Radio/ Stereo
    Dave,
    According to my 1972 Chevrolet Radio Parts Catalog the 1970-1971 Corvette AM/FM Stereo radio is Product No. 7303211. The sticker on the radio should have a sticker with this product number as well as Service No. 01VFM1 or 01VFFM2.
    0 = 1970
    1 = Chevrolet
    V = Corvette
    FM = AM/FM stereo
    1 (or 2 or 3) = revision number
    Try looking on Ebay or do a search on the web using these numbers.
    Dave
    • Mike F.
      • April 25, 2011
      • 668
      Here's my 1970 AM/FM Stereo, not original to the car. (When I bought the car it had a 1974 AM/FM Stereo installed). In 1970 the AM/FM Stereo option (at $278.10) was the fourth most expensive option available.
      I wasn't able to read my tank sticker, so I opted for an AM/FM Stereo unit. With both the AM/FM Mono and Stereo only having two speakers, in hind sight an AM/FM Mono would have worked just fine. You can't hear much "music" above 35mph anyway. The car noise doesn't bother me, but add in 1970 speaker technology and it gets to be a bit much after a very short time.
      For the AM/FM Stereo you will also need the (big box) stereo de-multiplexer (or stereo decoder) and (little box) convector.
      Here's where I bought mine, http://www.electrodesign.us/
      • David S.
        • August 9, 2009
        • 595
        Mike,
        Thanks so much for the pictures. That's exactly what I needed to see. I have an original AM/FM Stereo in my car now. I have to do some digging to see if the amps are still there. I suspect they are, as this car is very original and untouched.
        Best,
        Dave
        • Mike F.
          • April 25, 2011
          • 668
          Post some pics then.
          • Mike F.
            • April 25, 2011
            • 668
            Originally posted by David Schutzbank (50698)
            Mike,
            Best,
            Dave
            If you lay on the passenger side floor and look up, you should be able to see what's installed.
              • 43221
              Mike,
              Best,
              Dave
              Dave-----
              If the convector or adapter were not installed, the radio would not work.
              • Mike F.
                • April 25, 2011
                • 668
                Not sure why this is so small in my above post?
                • Jim T.
                  • March 1, 1993
                  • 5351
                  Mike the steel brace pictured for your 1970 coupe is something I do not have in my 1970 July built coupe. I bought my 70 new and still own it. Is you 70 a early model?
                  • Mike F.
                    • April 25, 2011
                    • 668
                    That last pic of the blue interior is not my car, it's probably not even a 70. (My car (9516) doesn't have a brace either). I found the pic on the WWW to show the decoder/convector.
                      • 15601
                      And here I was thinking of a white with blue interior. That has some appeal.
                      I am pretty sure that brace is a sign of a convertible, but I should leave this interior stuff to Reba.
                        • 43221
                        Terry-----
                        The under-dash tubular braces were a feature of C3 convertibles and were not used on coupes.
                        • Don L.
                          • August 31, 2005
                          • 1005
                          Terry-----
                          I think these braces doubled your protection in side impact crashes.
                          Don Lowe
                          NCRS #44382
                          Carolinas Chapter
                            • 43221
                            Don-----
                            Convertible bodies flex more than coupes due to the lack of the upper "cross brace" on the birdcage. So, the underdash braces were added to help compensate for this.
                            • Reba W.
                              • 937
                              That support brace runs under the dash from the transmission tunnel toward the outer right.
