Braided ground strap - NCRS Discussion Boards
  • David L.
    • July 31, 2004
    • 39
    Could someone verify that on a 64 factory air car the negative cable from the battery should be braided steel thank you. Dave
  • William C.
    • May 31, 1975
    • 6037
    Re: Braided ground strap
    If braided, it would be tin coated copper wiring rather than steel...
    Bill Clupper #618
    • David L.
      • July 31, 2004
      • 39
      Thanks for your quick reply Bill.
      • William C.
        • May 31, 1975
        • 6037
        Worked in the plants where those puppies were made for a while, the braid is actually made in a round hollow configuration then flattened after it's cut to length, terminated and fed into the lead mold.
        Bill Clupper #618
        • John F.
          • March 23, 2008
          • 2421
          I know that this is an old thread, but I need clarification on whether a 64 with a/c should have the braided negative cable on the battery. The Judging manual says "yes", but Lectric Limited and the AIM do not agree. LL does not even sell one for that application.
          • Joe R.
            • July 31, 1976
            • 4552
            The 1964 Corvette with or without AC did not have a flat braided copper negative cable.
            Also there is not mention of that in the AIM and a diagram is shown for both non AC and another in the AC section.
            JR
            • John F.
              • March 23, 2008
              • 2421
              Thank you Joe. That means the current Judging manual is incorrect then!
              • Joe R.
                • July 31, 1976
                • 4552
                That is only one error. There might be more. Better check with the Team Leader.
                Tell him I sent you.
                JR
