C-2 Chrome Cleaner REcommendation - NCRS Discussion Boards
  • Chuck S.
    • June 30, 1991
    • 184
    My 65 has been sitting covered in my garage and a slight film on the bumpers has appeared.
    Need help in selecting a chrome cleaner to remove the film and brighten up the chrome.
  • Loren L.
    • April 30, 1976
    • 4104
    Re: C-2 Chrome Cleaner REcommendation
    Chuck, back in the "Ice Age" the recommendation would have been your toothpaste tube....good luck and glad to hear that the car is still yours.....should have been at San Diego for showing.
      • November 30, 1989
      • 11611
      Soap and water?
      WD-40?
      Both will work.
      If you think you have to polish them at all try Flitz metal polish. It works great.
      • Steven B.
        • June 30, 1982
        • 3976
        I didn't think there was anyone else left! It worked great on yellowing nitrocellulose lacquer and plexiglass in the day, also. Steve
        • Paul O.
          • August 31, 1990
          • 1716
          What I used was just a quality glass cleaner like Windex you should just have to clean a chrome surface not polish it. If the the glass cleaner does not have any effect I would use lacquer thinner or similar to cut the film then clean with the glass cleaner.
          • Matt L.
            • February 22, 2010
            • 337
            i am with Paul on his advice. only adding NAPA glass cleaner with ammonia is also great. it's an aerosol can. i have also used an acid based wheel cleaner before with good luck.
            take care,
            matt
            • Gary J.
              • March 31, 1980
              • 1230
              Need to be careful with the silkscreen on the back though.
                • 15575
                The plater I used for hexavalent chrome (show quality) for my Chevelle said to only use Windex, but then I was starting with brand new chrome that is probably a lot better and different than what went on Corvettes back in the day.
                • Paul H.
                  • September 30, 2000
                  • 678
                  If your chrome needs a little help beyond a mild clean up, good old Dupont #7 brings back the shine.
                  • Mike E.
                    • February 28, 1975
                    • 5134
                    I've never seen mid year bumpers with silk screening on the back.
                    • Donald O.
                      • May 31, 1990
                      • 1581
                      I have had excellent results using MAAS compound, followed with a good carnuba wax, the non cleaning type of wax like Mothers #3.
                      DonO
                      The light at the end of the tunnel has been turned off.
                      • Gary J.
                        • March 31, 1980
                        • 1230
                        I had a brain burp. I was thinking about the air cleaner lid.
                        • Ronald L.
                          • October 18, 2009
                          • 3248
                          And there was the c cola trick too.
                          • John F.
                            • March 23, 2008
                            • 2395
                            Nevr-dull from O'Reilly's Auto Parts.
                            • Paul J.
                              • September 9, 2008
                              • 2091
                              Chuck, you've got it right, you clean chrome, you don't polish it. You won't find anything better than glass cleaner or soap and water. The ammonia content in glass cleaner is a very small % so it won't hurt the chrome.
                              Paul
