1968 Transmission Foam Collar Insulation - NCRS Discussion Boards
  • William H.
    • December 31, 2005
    • 209
    I have an early 1968 427 and wanted to ensure I was reading the TJM correctly. Is the foam collar installed on the bell housing? Thanks if you can confirm for me.
    Bill Hyndman
    The 'Sound of Freedom' if not a UH-60 Blackhawk, then it must be a Corvette!
    1962 Big Brake Fuelie
    1965 Fuelie Convertible
    1968 L89 Convertible
    • 15583
    Re: 1968 Transmission Foam Collar Insulation
    In 1969> it was glued to the bell housing before body drop. 1968 ... well who knows? Have you looked in your copy of the 1968 AIM?
    • Brian W.
      • September 30, 1990
      • 216
      My early 68 small block did not have a collar.
        • January 31, 1988
        • 43198
        Bill-----
        1968 did not use the foam shield ("collar").
        • William H.
          • December 31, 2005
          • 209
          Thanks, Joe. Much appreciated.
          Bill Hyndman
            • January 31, 1988
            • 43198
            Bill-----
            By the way, while the shields were not originally used on 1968 Corvettes and would therefore not be correct for a 1968, you could install one if you wanted to improve heat insulation for the passenger compartment. You can be sure that GM did not add these for 1969 because the 1968-without-shield design worked just as well.
            • Terry B.
              • August 31, 1999
              • 607
              Joe,
              Are you talking about the foil/insulation that goes in the transmission tunnel? If so, my Dec 67 built 68 had that type of material and had clips to hold it in place.
              Maybe we are talking about two different things.
              Terry Buchanan
              Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
              Corvettes Owned:
              1977 Coupe
              1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
              2003 Electron Blue Coupe
              2019 Torch Red Grand Sport Coupe
                • January 31, 1988
                • 43198
                Originally posted by Terry Buchanan (32872)
                Joe,
                Terry------
                Yes, two different pieces. The foil-backed tunnel insulation was used on 1968's. The piece were are referring to here was a rather large foam rubber collar which installed on the bellhousing and and sealed against the forward portion of the tunnel (forward of the foil-backed insulation). This foam rubber shield helped prevent engine compartment heated air from getting to the forward portion of the tunnel area (and thence radiating into the passenger compartment).
                • Gary H.
                  • June 8, 2008
                  • 308
                  The foam was missing on my 69. Reduced interior temps quite a bit after I replaced it. Some 69's also have a large foil covered fiberglass insulation under the body of the passenger compartment on the side of the transmission. I bought a set of the foil to put on my car but I didnt have any of the studs so I left it off.
                  Gary
                  • Dale C.
                    • October 31, 1999
                    • 844
                    Could there be any possibility of over insulating the pax compartment so as to create a heating problem for the eng. or trans.?
                    Dale
                      • January 31, 1988
                      • 43198
                      Gary
                      Gary-----
                      This foam shield is subject to deterioration and, after a period of time, it can just more-or-less "disappear". So, it may be that it was once present on your car but was long-gone by the time you looked for it.
                        • January 31, 1988
                        • 43198
                        Dale
                        Dale-----
                        In my opinion and with respect to the kind of heat insulation we're talking about here, there is just about zero chance that it's going to have any negative implications, at all.
                        • Henry J.
                          • October 31, 1999
                          • 457
                          Dale:
                          I installed one of these foam collars on my 68 BB. I consider it to be of great benefit.
                          • Robert E.
                            • March 31, 2004
                            • 398
                            Hi Henry, long time no see. When you installed the collar, was the engine and trans out of the car or did you slip it on from above through the firewall or from below?
                            Robert
                            Originally posted by Henry Jakubiec (33095)
                            Dale:
                            • John L.
                              • October 31, 1993
                              • 74
                              My early 68 BB vette with a turbo 400 trans had the foam collar. There was adhesive left on the top of the trans housing. The foam doesn't last. I'm not sure if a standard trans would be different.
