1034 vs. 1157 bulbs - NCRS Discussion Boards
1034 vs. 1157 bulbs
  • Stuart F.
    • August 31, 1996
    • 4676
    Re: 1034 vs. 1157 bulbs
    Do you really need some? If you have trouble finding #1034's, I have a bunch that I took out of my 63 back in 1976 and replaced with #1157's. Believe I got them from some Vette parts vendor in Ohio who now runs "Pro-Team". There weren't many vendors back then.
    Stu Fox
    • Edward J.
      • September 15, 2008
      • 6942
      Harry, See if you can find a auto parts store thats been around forever there maybe a chance they may have some old stock of the old brass base 1034's. You might get lucky and they'll have a box.
      • Paul J.
        • September 9, 2008
        • 2091
        Harry, I bought some off of eBay a few months back. They were not cheap.
        Paul
        • Harry S.
          • July 31, 2002
          • 5301
          This is in another post. Essentially the 1034 is correct for the flasher. They will flash slower and dimmer. The 1157 pulls more power and they will flash faster and are brighter.
          I have a combimation of 1157 and 2057, lots of erratic flashing.
          • Christopher R.
            • March 31, 1975
            • 1599
            If you have 1157s in your parking and tail lights, the correct flasher (Signal Stat ZN232 for 58-60, and ZN332 for 61-62) will not work correctly. In my case, the lights wouldn't flash at all. However, Tridon flasher LL552 will work just fine with 1157s. You can buy this LL552 flasher at your FLAPS for around $6. You can swap out the Tridon flasher for the correct flasher after Operations judging and before interior judging.
            • Patrick S.
              • January 1, 1988
              • 209
              Isn't "swapping parts" against the spirit of NCRS Judging???
              • Harry S.
                • July 31, 2002
                • 5301
                Not really, just don't swap parts on the Judging Field. I swap all the parts that are normally stolen such as gas cap, oil filler cap, dip stick, etc.
                • Vinnie P.
                  Editor NCRS Restorer Magazine
                  • May 31, 1990
                  • 1567
                  And if it's your own parts I don't see a problem like Harry says...the problem arises when you swap/borrow parts from another members car...that's a no no
                  • Dick W.
                    • 10483
                    #24
                    Such as the cigar lighter that was judged seven times at a meet. That was the meet that brought the parts swapping rule about. Not that I know anything about the lighter
                    Dick Whittington
                    • Vinnie P.
                      • May 31, 1990
                      • 1567
                      #25
                      Just like you don't know anything about extra sets of keys & moving cars around!!!!
