Non-H2O coolant - NCRS Discussion Boards
Non-H2O coolant
  • Michael W.
    • April 1, 1997
    • 4290
    Re: Non-H2O coolant
    Originally posted by Doug Loeffler (51544)
    Has anyone used non-water based coolant in a Corvette or other engine? If so what was your experience. Would you recommend using it in a Corvette engine? If so why? If not why not?
    Just wondering given the propensity of my 327 to run hot and / or overheat, even though the block was boiled, the radiator is new and the thermostat functions at the correct 180 deg.
    Doug, amongst other negatives the Evans coolant is less effective at heat transfer than either water or conventional 50/50 coolant mix. If you've got an overheating problem now, the waterless stuff will just make it worse.
