Clutch head screw source???? - NCRS Discussion Boards
  • Philip P.
    • February 28, 2011
    • 558
    Re: Clutch head screw source????
    John.. I was trying to get an idea without removing the screw, but in the end I did remove it just to make sure and it is as you state 1 inch from the bottom to the tip. It was hard for to get a good measurement while it was installed around the hood bracket.
    Don.. the only thing about your solution is to make sure the thread length in enough to tighten it.
    Next time I am wandering a wrecking yard I think I will be on the look out for clutch head screws on old GM cars/trucks.
    Phil
    • John F.
      • March 23, 2008
      • 2420
      Don, I had recommended you shave a little off since you said you had replacement panels that were thicker. My original 62 from the factory looks like this. Maybe your 60 is different.
