Low Gloss Paint - NCRS Discussion Boards
Low Gloss Paint
+ More Options
Posts
  • Walter R.
    • January 6, 2009
    • 271
    Low Gloss Paint
    I am repainting dash area and AIM lists Llow gloss paint for certain parts. What would be a recommended Krylon, Sem or alternative rattle can paint for this sheen? My interior is black.
  • Scott M.
    • January 1, 1996
    • 216
    Re: Low Gloss Paint
    SEM Trim Black works great in these areas.
    • Gene M.
      • April 1, 1985
      • 4232
      Re: Low Gloss Paint
      Walter,
      Krylon is ok but has been poor wear characteristics. I think Sherwin Williams owns Krylon now so it should be better quality. Sem would be a better choice. Many of the spray bombs are made by Sherwin Williams such as at Lowes.
      Fiberglass dash, speaker grill and center forward molding trim are satin with little to no sheen.
      • Keith B.
        • March 7, 2008
        • 928
        Re: Low Gloss Paint
        find a real hard wear store that sells the industrial line of Krylon. much better then the paint you buy at a big box store
        • Donald H.
          • November 2, 2009
          • 2586
          Re: Low Gloss Paint
          Here's another vote for SEM Trim Black. It expensive compared to the stuff you can buy at the hardware store, current Krylon.
          Don Harris
          Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
          • Hank D.
            • January 1, 1999
            • 137
            Re: Low Gloss Paint
            Ditto for SEM Trim Black. Just did my interior console with it and it looks great.
            • Mike E.
              • June 24, 2012
              • 920
              Re: Low Gloss Paint
              I'm not a big rattle can fan. If you want to go a different route I really like this Eastwood 2K single stage urethane. It's tough as nails and easy to work with. I would call it about 10% gloss. They call it underhood but IMO it's a little too flat so I add a tiny bit of 2K clear for my chassis parts. The image below is from their website and is good representation of the gloss level.
              Mike
              • Gary J.
                • April 1, 1980
                • 1244
                Re: Low Gloss Paint
                You need to be careful which interior items you are painting. Some items only a 3% gloss and the other items are at 60% gloss.
                • Jerry W.
                  • January 27, 2009
                  • 588
                  Re: Low Gloss Paint
                  Lost 11 points at Texas Regional on Interior items...Judges comment " should be glossy not flat "...Items now fixed, we'll see what they say next time around...I would recommend to error on the glossy side.
                  • Glenn D.
                    • May 31, 2002
                    • 137
                    Re: Low Gloss Paint
                    I used SEM on my interior and was very happy with the results. It can be used on vinyl , plastic , or metal. As with any paint or dye job , be sure to prep the surfaces. If you use SEM on plastic , be sure to use their primer. I believe it is called sand free.
