Pn# 7828875 - NCRS Discussion Boards
Pn# 7828875
  • James B.
    • March 1, 1985
    • 217
    Pn# 7828875
    Can anyone confirm this part number and application for me? I understand that it's a steering coupler, but not sure of this or what year(s) and application(s) it applies to.
  • Carl N.
    • April 30, 1984
    • 592
    Re: Pn# 7828875
    following may or may not help you
    SAGINAW 800 & 808 POWER STEERING GEARS:
    RECIRCULATING BALL KIT 7815988
    COUPLER (3/4" INPUT SHAFT) 7818568
    THRUST BEARING KIT 7826850
    COUPLER (13/16" INPUT SHAFT) 7828875
    • James B.
      • March 1, 1985
      • 217
      Re: Pn# 7828875
      Thanks for confirming the identification of the part, Carl. However, I'm also trying to confirm the vehicle application for this part. The seller indicates the (steering coupler - PN 7828875) applies to 70-82 Corvettes. However, I had recently purchased a steering coupler for my '72 (PN 7818658), as I understood it to be the correct part. Assuming I have the correct part, I'm just curious what PN 7828875 applies to).
        • 43221
        Re: Pn# 7828875
        James-----
        I can find no record of GM #7828875. I do not think it was ever a finished part number. It's very possible, though, that it is the part number or casting number of a component of an assembly, including, possibly, the L69-82 Corvette coupling assembly. For a SERVICE steering coupling, the assembly part number is usually only found on the box the SERVICE coupling is contained in.
        • James B.
          • March 1, 1985
          • 217
          Re: Pn# 7828875
          James-----
          Thanks, Joe.
