C1 "high lift cam" - NCRS Discussion Boards
C1 "high lift cam"
  • William F.
    • June 9, 2009
    • 1363
    C1 "high lift cam"
    What's the so called optional high lift cam on C1's? Is this the Duntov cam even though it's not high lift, but long duration, or something else?
  • John D.
    • December 1, 1979
    • 5507
    Re: C1 "high lift cam"
    Duntov 097 cam aka 3736-097. Readily available William from Federal Mogul. CS113R. Label on the box says Sealed Power by Federal Mogul. CS 113R. Make sure a clerk doesn't sell you a CS118R cam instead.
    Solid lifter #AT992. Available thru Car Quest and other chain stores. TOtal cost less than $200 with a discount. John
    • William F.
      • June 9, 2009
      • 1363
      wasn't wanting to buy one. Question is: Is the Duntov cam the cam Chevy referrs to as "special HIGH LIFT cam", even though design of Duntov cam is long duration, but relatively low lift, or is there another cam that meets the option description?
      • Jim R.
        • June 30, 2001
        • 643
        I think thats (duntov) it William the 30/30 didn't come out till 1964 = 254/254 dur 485/485 lft
        JR
        • William C.
          • May 31, 1975
          • 6037
          Yes, the "Duntov" cam was referred to in advertising as "high Lift" even though it is not.
          Bill Clupper #618
          • Steven B.
            • June 30, 1982
            • 3986
            Yep, 1957-1963.
            • Bruce B.
              • May 31, 1996
              • 2930
              In the era of 1957 through 1963 what was considered the numbers (lift & duration) that describe a high lift cam?
              • Jim R.
                • June 30, 2001
                • 643
                Duntov specs and these should be pretty close 228/230 dur and 394/399 lft, give or take a few degrees.I have heard that this cam runs about like a hyd L79 =221/221 dur and 447/447 lft but might not rev to where the duntov can, both are good small block cams though for drivers IMO.
                JR
                • Steven B.
                  • June 30, 1982
                  • 3986
                  Bruce, hope all is well. 'looks like you may get some weather. I have never heard a standard set of numbers describing what a high lift cam is. I think most people follow "I know it when I see it." I think it was often used the same as the terms "3/4 race cam" and "full race cam"---no specific specs. just what various performance cams were called by anyone.
                  Jim, I have used both of these cams and have a couple extra of each. I have also installed the L-79 '151 cam advanced 4 degrees and 6 degrees. They are both good cams in my opinion. I think the '097 is more fun compared to the '151.
                  Steve
                  • William C.
                    • May 31, 1975
                    • 6037
                    There was NO standard, it was strictly an advertising issue...
                    Bill Clupper #618
                    • Bruce B.
                      • May 31, 1996
                      • 2930
                      Steve,
                      Yep, we are going to see he last winter weather tomorrow, I wish.
                      My 67 had the 151 cam and I loved the performance, but you can't beat the Duntov in my 62. The solid lifters just do something for me.
                      I just had a 327 ( +0.060) built for the 57 gasser, 151 cam with the hilborn should be pretty peppy.
                      I also have the original 283 283 which I might put in the car with a Rochester unit on it. I still love the solid lifter sound.
                      • Stuart F.
                        • August 31, 1996
                        • 4676
                        There was also a time when the Power Pack cam was considered a "high Lift" performance cam, least wise we put one from a 56 Power Pack engine (4 barrel) into a 55 (2 barrel) V8 back in the day and realized improved performance. The manifold was swapped out for the 4 barrel as well as dual exhausts were added. It was still a hydraulic lifter cam, but the car with a Powerglide slush box dropped more than a half second in the quarter. I don't have any of the cam specs, but it was a common and cheap upgrade to the base 165 hp V8.
                        Stu Fox
                        • William F.
                          • June 9, 2009
                          • 1363
                          Have to let you know that the L79 cam is almost identical to the specs of the "30-30"cam used in '64-'64 hiperf SB's,(except for lifters. It's not the same as the 097 Duntov.L79 and 30-30 have much higher lift than the Duntov.
                            Have to let you know that the L79 cam is almost identical to the specs of the "30-30"cam used in '64-'64 hiperf SB's..
                            Bill -
                            Actually, those two cams couldn't be more different; their behavior isn't even close.
                            • William F.
                              • June 9, 2009
                              • 1363
                              John,
                              Respect your knowledge a lot, but here's where I'm coming from: Lift patterns for 30-30 and the 151 cam are almost identical(taken from a diagram in an old issue of "Corvette News") There are some differences in duration and overlap. 30-30 duration 446*13", overlap118*13"; L79 (151) duration342*, overlap114*.L79 cam(and 30-30 cam) i much different from the Duntov cam as I'm sure you know. Was just letting other poster know this difference.
