Turn signal switch - wire attachment - NCRS Discussion Boards
  • Steve M.
    • October 21, 2008
    • 59
    Thanks in advance for any help here.
    To start, I searched the archives, including All 97 pages of the 63-64 threads....
    I also looked at AIM.
    Here is the question:
    The internal turn signal cable attaches to the switch at the lower end of the column.
    During removal of interior, some idiot.... (Me) managed to pull that wire off the switch.
    How exactly does the switch captivate the wire? It seems pretty flimsy.
    once I figure out how to properly reattach down near the firewall end I assume it will have to be adjusted so the middle sliding position matches the "off"position of turn signal stalk
  • Bob R.
    • June 30, 2002
    • 1595
    Re: Turn signal switch - wire attachment
    It is not a great connection. The metal wire just slides into the clip on the directional switch. Really not very difficult. Center the clip on the switch and have the directional arm in the center position and slide the wire into the clip. Test to make sure it works properly.
    • Steve M.
      • October 21, 2008
      • 59
      Thanks! It just seemed very hokey......I appreciate the help!
      • Troy P.
        • February 1, 1989
        • 1284
        63 only. They changed the switch to a better design in 64.
        • Steve M.
          • October 21, 2008
          • 59
          I assume after playing around with it that you press down on springy tab, slide wire through and release pressure on tab,,thereby pressing wire up against upper top catches?
          correct?
          • Troy P.
            • February 1, 1989
            • 1284
            Correct. That's how it works. AIM gives instructions also.
