caution on GM Tech 2 & CANdi purchases - NCRS Discussion Boards
  • Ray G.
    • May 31, 1986
    • 1189
    Department of JusticeOffice of Public Affairs
    FOR IMMEDIATE RELEASE
    Wednesday, September 26, 2012
    Virginia Man Pleads Guilty to Trafficking in Counterfeit GM Diagnostic Equipment
    12-1159
    Criminal Division
    I hope you dance
    • 15616
    Re: caution on GM Tech 2 & CANdi purchases
    Good post Ray. I sent it on to a colleague who is a Chevrolet tech. His response:
    "This has been going on for a while.
    We have been told that if we want to buy a Tech 2 that we should get the serial number form the unit and then call GM and they will verify if it is legit.
    The easiest way to tell a fake Tech 2 is check the expansion slot door. Fake ones are plastic. Real ones are metal.
    I have heard that some of those candi modules have nothing inside them.
    Thanks!"
    • Ray G.
      • May 31, 1986
      • 1189
      Real CANdi modules have a clear indicator light that turn green when in use. Counterfeits have a green lens.
      Real CANdi modules have aluminum connector terminal material. Counterfeits have brass looking terminal s in the connectors.
      Received the following from a friend in MN.
      NO PRODUCTION DATE INSIDE THE COVER FOR
      THE 32 MB SOFTWARE CARD, IT'S A CLONE.
      IF THE PHONE NUMBER FOR SUPPORT ENDS IN ... ... 4009,
      DEFINATELY A CLONE.
      IF THERE IS NO SUPPORT PHONE # AND NO PART NUMBER
      (THE SPACE ABOVE THE SERIAL NUMBER IS LEFT EMPTY)
      IT'S A CLONE.
      THE VOID STICKER OVER A BOLT HOLE IS
      NOT COMPLETELY CLEAR TO READ,
      IT'S A CLONE.
      IF YOUR TECH 2 HAS LITTLE WHITE STICKERS
      OVER THE CASE 1/2'S WITH 'VETRONIX'
      AND CHINESE SYMBOLS INDICATING DATE,
      DEFINATELY A CLONE.
      ANY LABEL ON THE RIGHT SIDE OF THE TECH 2 CASE 1/2'S
      WITH A PRODUCTION DATE CODE IS A CLONE.
      BEWARE!!!!! THERE ARE MANY CHINA TECH 2'S
      BEING SOLD BY LOCAL USA ADDRESS'S AS 'LIGHTLY USED'.
      I hope you dance
