C2 rear suspension / handleing problem - NCRS Discussion Boards
  • Stan E.
    • April 30, 1991
    • 383
    I have a C2 rear suspension problem. All parts are new except the original (63) spring was rearched to spec. When I accelerate ,only 300 HP, the rear of the vehicle goes down and seems to pull the rear to the right. I must steer to the right. When I decelerate the rear of the vehicle comes up and the front of the vehicle must be steered right. Passed PV. Dangerous! Everything is tight,no broken welds and I believe the posi to be free. HELP!
  • Harry S.
    • July 31, 2002
    • 5338
    Re: C2 rear suspension / handleing problem
    When the rear spring was installed was the final torquing done with the wheels on the ground? If your not sure check the spring, are all the leaves still aligned or have they twisted out of shape.
    • Larry M.
      • January 1, 1992
      • 2701
      Stan:
      Was a rear alignment done after the rear suspension work?? What were the final settings??
      Larry
      • Dick W.
        • 10483
        I most definitely would check all the bushings, front and rear plus have a four wheel alignment performed. The squat on acceleration and the raising of the rear on decel are normal, what is not is the pulling. I suspect that you have a bushing(bushings) worn and allowing a caster change causing the pulling.
        Dick Whittington
          • 15625
          Also check the bushing at the front of the differential. If that bushing is worn the car will squat more than normal and may want to pull to the right on acceleration.
          • Michael W.
            • April 1, 1997
            • 4290
            Possible some trailing arm alignment shims fell out. Very common when later slotted shims are used on an early car with no retaining cotter pin.
            • Jerry G.
              • April 1, 1985
              • 1022
              Toe in setting in the rear is very important. The suspension will go through toe in to toe out in compression so if you don't start out with enough on both sides you will get this type of behavior. I had it in turn 5 at Laguna Seca.
              • Stan E.
                • April 30, 1991
                • 383
                Car has total restoration with 105 miles on Duntov. It's all new with 3 allignments, all new parts front and rear, everything is tight. I welded welding rod over shim openings. It took 7 Cooker 6/70-15's to get four to balance.
                  • 6954
                  Stan, from what your explaining it sure sound like the posi clutchs are locked. Years ago when at a Chevrolet dealership we to have Joie Chitwood thrill show come to town for a yearly town fair and If you don't know them they were stunt drivers who like to drive on two wheels.and of coarse they where all Chevrolets. and every year they would break something, rear ends, and transmisson where common, I did the major repairs on there cars. and we always welded the gears in the rear diff. and they also use front drive cars and the transmisson spider gears were also welded. if you ever drove these cars on the open road , they drive like what your explaining, accelarating the car goes in one directional and when decelarating the other way. is this what your experiencing?
                    • 43263
                    Stan------
                    Does all parts being replaced include the large cushions installed on either side of the differential crossmember?
                    • Mike E.
                      • June 24, 2012
                      • 920
                      What about one bad as in totally not working shock?
                      Mike
                      • Michael W.
                        • April 1, 1997
                        • 4290
                        Upper A arm alignment shims fell out, leaving a gap.
                        • Stan E.
                          • April 30, 1991
                          • 383
                          Joe, car has new crossmember cushions. Front end is tight. Shocks are all new. Ed, posi has double lube. How hard do rear wheels turn in opposit directions while on a lift? THANKS !
                            • 6954
                            Stan, I truely don't know if you can over come the spring tension on the posi clutchs while the car is on lift and spinning wheels. Does the car act like what I said in my prev. post while you accel and decel? What does the car act like on tight turns in a parking lot?
                            • Dick W.
                              • 10483
                              Pay attention to Jerry's post, he has been there, done that, and got the tee shirt to prove it.
                              Dick Whittington
