trying to remove the seat tracks on a 63. any idea how. thanks.
HELP 63 seat frame
Re: HELP 63 seat frame
Gary. I do not believe that it will dissay. there are some ball bearings internally that the tubes slide on. did the ball bearings maybe fall out?New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
I don't know what's inside of the tube. The back part of the piece that slides in the tube works great. it's the front that's loose. I'm trying to get the sliding piece out to see what's in there, so I can fix it.- Top
Gary, On the back of the seat frame there is a small metal strap welded to keep the slider in place. You will need to cut the welds on this and remove it. Once you have repaired the slider you can re-weld the small strap in place. Joe- Top
Thanks Joe, do you know what holds the 2 rollers to the slide. The front one keeps coming off when I slide the track back and forward. Maybe sitting in the seat would put pressure on the roller and keep it there? Thanks.- Top
