Correct Timing Chain Cover for 1960 270hp? - NCRS Discussion Boards
  • Mark S.
    • January 26, 2013
    • 88
    Looking for a Timing Chain Cover for 1960 270hp. Does one Timing Chain Cover fit all engine configurations or is there a unique Cover for the HP cars? GM Part number and pictures of the correct Cover would be helpful. Thank you.
    • 43247
    Re: Correct Timing Chain Cover for 1960 270hp?
    Mark-----
    The timing cover was GM #3704124. However, the number is not found on the cover and I doubt you'll find an NOS example (with this number on the box). These covers are not rare and can be found on many passenger cars of the period as well as Corvettes. All of the basic covers were the same; the differences lie in the timing pointer. However, I think all of these earlier covers were set up with a pointer for 6-1/8" balancers
    • Tom D.
      • September 30, 1981
      • 2137
      Does this look correct? It's the 290 HP version with a reproduction balancer.
      https://MichiganNCRS.org
      Michigan Chapter
      Tom Dingman
        • 43247
        Tom-----
        The basic cover is correct. I'm not sure about the timing tab as I'm not that familiar with the nuances of C1 timing tabs.
        • Loren L.
          • April 30, 1976
          • 4104
          If it's the Goat Hill Repro, it will be wrong, inasmuch as the diameter of that balancer was 6 1/2", not 6 1/8".
          • David L.
            • July 31, 1980
            • 3310
            I believe that the timing cover (in very poor condition) in my photos below is a 1955-1961 timing cover, GM # 3704124. I bought it for $1 at a swap meet just for research purposes. The tab measures 3.15"+/- from the center of the crank hole.
            Dave
            • David L.
              • July 31, 1980
              • 3310
              Tom,
              The tab on your cover looks like the 62-E64 type.
              Dave
              • Mark S.
                • January 26, 2013
                • 88
                David, by chance do you have a sketch of what the tab looks like for a 56-61 Cover?
                • David L.
                  • July 31, 1980
                  • 3310
                  Mark,
                  All that I have is the shape of the pitted timing cover tab in my 2nd photo. I can make out about 90% of the lines, the "0", and the "R". I can not see the "A" but I assume that it is there somewhere. The tab measures 1.19 and 0.88" in width.
                  Paragon makes a repro 56-67 tab which, in my opinion, looks like the 62-E64 tab.
                  Dave
