1967 NON-STOCK wheel fit - NCRS Discussion Boards
  • Donald O.
    • May 31, 1990
    • 1593
    Well, after spending a futile hour searching for an answer in the archives, I'll ask here. And this asked only about the 67 Vette with stock, original calipers.
    Does the American Racing Torque Thrust D wheels fit with or without spacers? The size 15x6 wheel for a 205-75R15 or the 215-70R15 tire would be used
    Since my 67 has not sold and I guess I'm going to keep it a while longer, I thought I'd change the appearance a bit. The original ralley wheels, trim rings and caps are not for sale and will be kept.
    Thanks, I know this sounds like a type heresy here, but I thought I would ask the group that knows the most.
    DonO
  • Philip A.
    • February 26, 2008
    • 329
    Re: 1967 NON-STOCK wheel fit
    Fits without spacers. Have them on my 65
    • Steven B.
      • June 30, 1982
      • 4011
      Don, I have a friend with the 15X6 TT's on his '67 coupe. I think the tires are 205's but not certain.
      Steve
      • Michael J.
        • January 27, 2009
        • 7167
        Here is my '67 with Torq-Thrust Ds and DiamondBack radials, 205s. Fits great, no spacers, got the wheels from Tire Rack, they know the wheel needed.
        • Gene M.
          • April 1, 1985
          • 4233
          If tire is less than 25 7/8" in diameter it will fit in tub. But this is actual measure not something pulled off a chart. Be cautious of the width as the lid will not close if to wide. You will need two squares to measure the outside diameter accurately over the center of the thread.
          • Donald O.
            • May 31, 1990
            • 1593
            Gene,
            Not worried about the tub as I have a ralley with red stripe bias ply POS Coker cr*p for a spare. Fits just fine though and iys only purpose is to b=get me either home of to a tire store for a repair.
            DonO
            • Scott M.
              • January 1, 1996
              • 216
              Here is my '67 with 15x6 Vintage TTs, 205x65 V rated Potenza tires no spacers required. WP_001442.jpg
              • Patrick S.
                • January 1, 1988
                • 209
                Scott,
                Do you happen to know the back spacing of the real original TT as shown on your car? I always thought that it was a negative number. I am looking for a set for my 62 FI.
                Pat
                • Scott M.
                  • January 1, 1996
                  • 216
                  Hi Pat, I want to say the BS is 3.5" but I will pull off a wheel and measure it to be sure.
                  • Scott M.
                    • January 1, 1996
                    • 216
                    I removed a wheel and measured from the mounting pad to the outside of the wheel, it is 3.5".
                    • Patrick S.
                      • January 1, 1988
                      • 209
                      Scott,
                      If they are 6" wheels and the backspace is 3.5" that means they are "inset" by 1/2 inch. Perhaps that is why the question about a spacer. I used a pair of the "original" TT "D"'s on the front of my drag race 57 Vette in the 70's and they looked great. I am looking for a set now for my 62FI car.
                      Pat
                      • Donald O.
                        • May 31, 1990
                        • 1593
                        So what is the bolt pattern for my 67 Vette?
                        What is the designed offset and backspacing from GM?
                        • Scott M.
                          • January 1, 1996
                          • 216
                          Bolt pattern is 5 x 4.75". The stock 6" rally wheels for 1967 had +.06" offset, which equates to 3.56" backspace.
                          • Michael J.
                            • January 27, 2009
                            • 7167
                            This is what Tire Rack says about the American Racing Torq-Thrust Ds I got for my '67:
                            • Donald O.
                              • May 31, 1990
                              • 1593
                              Now all I have to do is decide on either red stripe or blue stripe tires.
                              Thanks guys.
                              DonO
